A/C problem need HELP!!!! :(
Ok heres the deal. My compressor turns itself off when the condenser (radiator looking thing that is in front of the radiator) gets too warm, like when the car is sitting at idle, the compressor will turn itself off, and my a/c will cease to blow cold air. But whenever I spray water on the condenser, the compressor immediately kicks back on.
I have the OEM condenser fan, but a smaller aftermarket radiator fan with no shroud, just zip tied to the radiator. Both work fine, but the condenser fan only turns on when the a/c compressor is on.
Can this other, non OEM fan be the reason my condenser is getting too warm and causing my a/c to shut off? Do Hondas have a pressure cycling switch?
The aftermarket fan runs all the time, and the car never gets anywhere near too hot. Hell it never even gets above half way on my gauge. If any of you have had a similar problem and found the solution, please let me know! Thanks!!!
to those who help
to those who help
RICE POLICE SIP
30
Oct 6, 2003 05:19 PM
