Aftermarket Stereo Not Getting Power in EG
Old Jun 29, 2006 | 05:44 PM
iplaybass's Avatar
Default Aftermarket Stereo Not Getting Power in EG
I just bought a cheap "DUAL" deck from Best Buy to hold me over and low and behold nothing. The wiring harness was thrashed so I wired straight to the car (followed http://www.installdr.com/). The only wire not used on the deck is blue (electric antenna). Fuses are all fine (under hood and under dash). I have to be missing something and YES I did search. Any help would be awesome.
Old Jun 29, 2006 | 06:00 PM
B18C_EJ8's Avatar
Did you verify which wire isn't getting power with a meter or test light?
Probably need to start there, and figure out exactly which wire is the problem, then you can either try to fix that wire, or just run a new one from the fuse box or ignition harness....
If you verify that the deck is getting constant 12v, and switched 12v, and you've verified that your ground is good, then I would say that you have a DOA deck... I saw it all the time with those decks.
Old Jun 30, 2006 | 09:40 AM
CB7.v2's Avatar
you should ground the headunit to the chassis...
Old Jun 30, 2006 | 02:35 PM
suspendedHatch's Avatar
Default Re: (CB7.v2)
Check the 7.5A fuse under the hood (ecu backup) and then check the dome light fuse in the driver's kick. This is assuming of course that you're using the factory power wires, which you should be. If you run your own wires, you can solder into the ignition harness.
Old Jul 1, 2006 | 12:53 AM
iplaybass's Avatar
Thanks. I'll give these all a shot tomorrow.
Kyle700
Audio / Security / Video
Oct 17, 2014 09:08 PM
vtak2nr
Sep 8, 2011 08:02 PM
646EG
Aug 30, 2007 09:20 PM
Leo C
Jan 20, 2007 06:01 PM
O RLY
Nov 3, 2005 07:30 AM
