HELP LUG ARE STUCK ON MY STUD
do any one know any tips or stuff i can do to take it out i cant take my rims out
ps the stud thing is stripped i forgot what its called
the thread that holds the lug stud stripped so it is no way i can just put on new lugs i wish it was that easy but i screw it up thank or can i fix it
Not new lugs, new studs. That's not the same thing.
The stud is the thread that the lug goes on. It is attached to the hub. You can take your stripped stud out of the hub and put a new one in. I'm kind of confused on your problem though, the way that you're describing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">do any one know any tips or stuff i can do to take it out i cant take my rims out
ps the stud thing is stripped i forgot what its called</TD></TR></TABLE>
this happened to a friend of mine on his teg. he messed up on taking the wheel off and his "stud thing" (dunno whut its called either) was cross threaded. basically after that you can try this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak »</TD></TR><TR><TD CLASS="quote">hammer on a impact bit and use a impact wrench (air wrench)</TD></TR></TABLE>
my friend continued to unscrew and the lug came off along with a piece of the "stud" inside the bolt. ruined 3 of his studs. took it to a wheel shop and they replaced em for like $4.50 each lug i think.
good luck
good luck
