how to install a greddy turbo timer without optional harness
ok i just went through this this weekend, buy a hanyes manual, it will show you the accessery, the on, and then another one go through the wiring diagram and figured out which on is on at which phase. isnt that hard hardest part was getting to the plugs.
http://www.2gic.com click teg tips go to interior pick integra accessary wiring all ur ??? will be answerd.....i just did the apexi turbo timer last week it was not hard at all just tap ur o2 sensor from under the hood and just ground it to chassis and ur good dont tap the ecu its works the same way and i get all readings perfect...
ZCHF
Jun 11, 2004 01:29 PM
