Automatic to Manual ECU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JShull »</TD></TR><TR><TD CLASS="quote">I thought that you could use the auto ecu with no troubles it will just throw a CEL over the auto shift solenoid not being there?</TD></TR></TABLE>
It will throw a code but also drive all shitty and the idle will be all screwed up. At least when I tried.
d16y7 - P2E
d16y8 - P2P
Which ECU you have to buy is depending on the year of your car. (OBD2a/OBD2b)
and like SkoundrelUSA said... the auto trans ECU will throw a CEL and will not run right.
If you really want to fool it into thinking the auto trans is there you might be able to but picking up a manual trans ECU would be a ton easier.
d16y8 - P2P
Reasons why you can NOT use auto obd2 ecus for manual cars.
1. Auto is for auto cars (duh)
2. Auto ecu runs 3 wire IAC while manual runs 2wire (aka very bad idle)
3. Auto ecu looks for the auto solinoids (sp?)
4. Because i said so ::shrugs::
Fook_me_honda
Jan 9, 2008 11:58 PM
ringgold
Sep 29, 2004 12:02 PM
