Code 41, o2 heater... cant shake it
Just did the the obd1 conversion on my 91 hatch. Using a p28 with a stock p28 basemap and the rywire conversion harness.
I initially started the conversion with a used 4 wire o2 sensor but when I could not get rid of code 41 I went out and bought a new denso fitted 4 wire o2 sensor for a d16z6.
From the rywire harness to o2 sensor I have:
rywire -> o2
brown = black
purple = blue
yellow = black
grey = white
I tried swapping the black wires, and the colored wires. In between each wire swap I disconnected the neg terminal on the battery and hit the brakes a few times.
Anyone have some suggestions? This is the only code I am throwing.
rywire -> o2
brown = black
purple = blue
yellow = black
grey = white
hey i have the same problem with you i just picked up a rywire conversion harness and i'm throwing the same code 41. i didn't try and swap the colors around yet and i'll probably try and do it this weekend...bump for some answers
Im gonna go search for my multimeter/continuity meter and start tracing the o2 wires from the ecu to the harness extension. I emailed rywire for some guidance, hopefully its something stupid easy to fix.
rywire -> o2
brown = black
purple = white
yellow = black
grey = blue
OR
rywire -> o2
brown = black
purple = green
yellow = black
grey = white
brown = black
purple = white
yellow = black
grey = blue
OR
rywire -> o2
brown = black
purple = green
yellow = black
grey = white
Coltmorris
20
Mar 8, 2009 08:42 AM
civicflow
10
Jan 23, 2007 09:56 PM
