96 EK hatchback wing - bulb replacement
when you look at the third light you will see 2 clips on each side and all you do is pop them out with a flathead screwdriver. then you will see 2 screws that you unscrew, once you unscrew them you can pull it right out and get to the light bulb.
yes i just did this... remove the interior panel right under the wing and unscrew the 4 bolts. then take the wing off and take the bulb out and replace it with the small wedge type bulb
Todd00
11
Apr 29, 2016 04:15 PM
RA61825
May 28, 2006 11:52 AM
CRacer21
Jan 12, 2006 07:28 PM
hothatch
Jun 28, 2001 01:18 AM
