Idle Noise?
Old Apr 18, 2002 | 08:20 AM
Black Sheep's Avatar
Default Idle Noise?
Guys, what does your ITR sound like with the stock pipe on idle, mine sounds like a London Taxi (not sure if you know what I mean) (Kinda rough as the taxis run on diesel) is this normal?
It's always sounded like this, there's nothing wrong right?
Thanks.
[Modified by Black Sheep, 5:21 PM 4/18/2002]
Old Apr 18, 2002 | 09:13 AM
DutchITR1689's Avatar
Default Re: Idle Noise? (Black Sheep)
Like ticking noise? check the valve adjustment...
Old Apr 18, 2002 | 09:15 AM
Default Re: Idle Noise? (Buzz8400)
HUh? there's nothing more, it sounds like a diesel engine on idle, I wouldn't say it's spluttering but the engine sounds strange for this kinda car. Sounds like it dosen't belong, until you go to highr revs anyway.
[Modified by Black Sheep, 6:16 PM 4/18/2002]
Old Apr 18, 2002 | 09:18 AM
HUh? there's nothing more, it sounds like a diesel engine on idle, I would say it's spluttering but the engine sound strange for this kinda car. Sounds like it dosen't belong, until you go to highr revs anyway.
Old Apr 18, 2002 | 09:19 AM
Maybe Americans don't know what a Diesel engine sounds like......
It could be pinging or valve clearance...
Old Apr 18, 2002 | 09:27 AM
Default Re: Idle Noise? (DutchITR1689)
That kinda sound serious, it was like that when I brought it.
What do I need to do to confirm this.
Willard's Avatar
valves...
what rpm is indicated? ~800 or so?
Will
-who likes diesel power
Old Apr 18, 2002 | 09:33 AM
Default Re: Idle Noise? (Willard)
when you first start it it varies sometimes above 1k and sometimes below, I've not really noticed what it idles at when warmed up, it should be 1k exactly right?
Old Apr 18, 2002 | 09:38 AM
Willard's Avatar
~800 or so once it is warmed up with nothing turned on.
Will
-who has adjusted his valves twice in ~48,000km's
Old Apr 18, 2002 | 09:40 AM
I'll check tonight, thanks.
Rtzx9r
Honda S2000
May 18, 2007 10:22 PM
White98LS
May 7, 2007 11:07 AM
dmxsoulja3
Mar 21, 2005 08:24 PM
EF8_SiR
Sep 20, 2002 05:51 PM
