VTEC KILLER CAMS for H22!! already exists? custom maybe ? need info!!
Old Jun 28, 2006 | 06:31 PM
JinMTVT's Avatar
New User
Default VTEC KILLER CAMS for H22!! already exists? custom maybe ? need info!!
Do you guys know of companies making non vtec cams for H22a engines?
( by no vtec i mean like Toda Vtec Killer cams .. only 2 full lobes, no vtec lobe )
working on a race project, and VTEC poses a 100lbs penalty
If it doesn't exists,
wich custom camshafts company could be able to do that for us?
thanks all
Old Jun 28, 2006 | 07:47 PM
A Blue Lude's Avatar
Default Re: VTEC KILLER CAMS for H22!! already exists? custom maybe ? need info!! (JinMTVT)
http://www.pocketrocketsracing.com/
Ask Frank. He could probably come up with something for ya.
Old Jun 28, 2006 | 08:03 PM
DAGAME's Avatar
as far as i know TODA only makes cams for b and k series
Old Jun 28, 2006 | 08:10 PM
94Vtecluder's Avatar
Default Re: (DAGAME)
I'm pretty sure they exist there was a thread on here posted by someone who was using them I believe. Don't know much though sorry.
Old Jun 28, 2006 | 08:53 PM
98vtec's Avatar
moderator emeritus
Default Re: (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure they exist there was a thread on here posted by someone who was using them I believe. Don't know much though sorry.</TD></TR></TABLE>
you can lock the rocker arms to only operate off the vtec lobe, but thats about all i know you can do for the h22. I know that there arent any produced vtec killers for our motor.
i'd definitely give Frank a ringy dingy
Modified by 98vtec at 8:10 AM 6/29/2006
Modified by 98vtec at 8:11 AM 6/29/2006
Old Jun 28, 2006 | 08:55 PM
hu's Avatar
hu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinMTVT &raquo;</TD></TR><TR><TD CLASS="quote">If it doesn't exists,
thanks all </TD></TR></TABLE>
Try webcamshafts.com
They will make a custom grind to your specs. or even help you figure out what your specs should be.
Old Jun 28, 2006 | 10:38 PM
MLBZ521's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">you can lock the rocker arms to only operate off the vtec lobe, but thats about all i know you can do for the h22. I know that there arent any produced vtec killers for our motor.</TD></TR></TABLE>
^^ To what 98vtec said..
You can do that and use a Cam in the sense that it ONLY has the VTec Lobe, rather than the idle and normal running lobe.
So.. Basically you're running/idle-ing on the VTec Lobe..
I do know a guy selling these if you would like a pair of them..
Also, I kinda had a question about these since we're on this topic..
I've heard of "VTec Killer Cams" and "VTec Eliminator Cams," now I don't know if people just call them different, or come up with different names and it gets spread around.. But is there any difference between the two?
I get the hint in the "Eliminator" Cams, but are "Killer" Cams the same also? Just wondering..
Old Jun 28, 2006 | 10:41 PM
98vtec's Avatar
moderator emeritus
Default Re: (MLBZ521)
same things
killer meaning removing....same thing as eliminating
Old Jun 28, 2006 | 11:00 PM
AznBlueBoy's Avatar
theres some for sale in the fs thread.
Old Jun 28, 2006 | 11:29 PM
MLBZ521's Avatar
Default Re: (AznBlueBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">theres some for sale in the fs thread.</TD></TR></TABLE>
Yeah, those are the one's I was talking about.. They're by RS Machine, custom and everything... VERY Big.. I have pictures of them... Supposed to be bigger than Juns..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">same things
killer meaning removing....same thing as eliminating </TD></TR></TABLE>
So then 98vtec, what are the Cams with ONLY the VTec Lobe called??
Not trying to sound smart there, if you read it that way..
Just wondering this as I see them all called the same.. And it confusing me!!!! lol
Old Jun 29, 2006 | 04:22 AM
JinMTVT's Avatar
New User
thanks guys for the input
we could always run only ON the vtec lobe
wich would technally disable the variable valve thus getting us rid of
a 100lbs dead weight
but since we might have to go with custom cams neway,
i think that i'll contact some of the cam company and see if they can make
a reagular non vtec cam for this engine ( shouldn't be too hard i guess )
do you guys know the maximum opening on the valve before the assembly hits the guide? then maximum valve opening that actually gives something
( point where more means nothing )
Old Jun 29, 2006 | 04:25 AM
mgags7's Avatar
i believe clearance on stock h22 stuff is .470 of lift
crane cams makes vtec killers for the h22 if i remember right
try talking to user hseriesmm, he would know, and possibly has a set for sale....
Old Jun 29, 2006 | 06:45 AM
JinMTVT's Avatar
New User
Default Re: (mgags7)
is that from a "regular valve adjustment ??
cause taking into account the play on the valve adjustment..
and for regrinds ...
Old Jun 29, 2006 | 08:26 AM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">try talking to user hseriesmm, he would know, and possibly has a set for sale....</TD></TR></TABLE>
^^The Exhaust Cam he has is: "the lift is at 478 with a 260 duration."
And the intake cam is bigger.
Old Jun 29, 2006 | 10:38 AM
Finest's Avatar
Default Re: (JinMTVT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinMTVT &raquo;</TD></TR><TR><TD CLASS="quote">we could always run only ON the vtec lobe
What racing sanction adds a penalty for having VTEC? If anything, you should get a break!
Old Jun 29, 2006 | 10:57 AM
Silver Surfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">
Just wondering this as I see them all called the same.. And it confusing me!!!! lol</TD></TR></TABLE>
it's confusing b/c you are refering to "vtec" as a noun instead of an action that occurs......the action is being eliminated or killed because there is now only one lobe
Old Jun 29, 2006 | 02:27 PM
Rosko's Avatar
Default Re: (Silver Surfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">i believe clearance on stock h22 stuff is .470 of lift
those crane cams with the roller rockers would be sick.
Frank's the guy to talk to about those too.
Old Jun 29, 2006 | 02:28 PM
mgags7's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">those crane cams with the roller rockers would be sick.
Frank's the guy to talk to about those too.</TD></TR></TABLE>
hell yea roller vt ftw
Old Jun 29, 2006 | 02:33 PM
Mr.Slippyfist's Avatar
M22 I think...
Old Jun 29, 2006 | 02:37 PM
98vtec's Avatar
moderator emeritus
Default Re: VTEC KILLER CAMS for H22!! already exists? custom maybe ? need info!! (Mr.Slippyfist)
thats not a vtec killer cam. Its a regular cam made by Rocket.
Old Jun 29, 2006 | 07:44 PM
machine4321's Avatar
ok was on the crane site and it seem from there specs there not the biggest casm out there , im guessing they cant go to big with them as they wont idle well enough .
so really for overall performance is it better to stay with a vtec cam and have a tolerable lowend and have more top end , or am i missing somethign here ?
http://www.cranecams.com/?show...-0514
Old Jun 29, 2006 | 07:46 PM
dam and judging by the price of them they better work better then anything else out there
so lets disscus the gains from these ,
they claim 52%ligter (the roller rokers) this would amazing for reving high and keeping friction losses at minimum , would be right in thinking that you would also be able to use a softer spring making the friction even less an issue ?
and how unusable would the bottom end power be .
Old Jun 29, 2006 | 07:49 PM
Rosko's Avatar
Default Re: (machine4321)
I'm pretty sure they will do any grind you want, but yeah as with any non vtec type valvetrain you will lose idle quality, buts its just the compromise you have to live with if you want the power.
and yeah the price sucks but theyre so damn cool!
Old Jun 29, 2006 | 07:55 PM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">it's confusing b/c you are refering to "vtec" as a noun instead of an action that occurs......the action is being eliminated or killed because there is now only one lobe</TD></TR></TABLE>
Well, isn't there a difference between the Cams with only the VTec Lobe and Cams with only the Idle & Normal running Lobe??
^^A name difference I mean..
Old Jun 29, 2006 | 07:56 PM
**** they make some huge as grinds . theres there custom race grinds just below the h22 race rollers , dam i wish i had money i would love to have those lol
http://www.cranecams.com/?show...ON009
thats just the intake cam alone
Modified by machine4321 at 12:13 AM 6/30/2006
