pipe notching with end mill
anyone else do it this way? i love it.
see photos for idea at:
http://pg.photos.yahoo.com/ph/...21re2
tom
tom
actually if I had a mill, I would do it this way,
I know there is a compagny that sell a carbide bit similar to this one, except that you can attach it to a press drill and use the vise to moove the pipe foward.
I saw this at horspower Tv just can't remember the name of the compagnie that make the bit.
jp
jp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kranked91dx »</TD></TR><TR><TD CLASS="quote">actually if I had a mill, I would do it this way,
jp </TD></TR></TABLE>
that does work but drill press spindle/bearings arn't designed to take any sort of side load
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy »</TD></TR><TR><TD CLASS="quote">that does work but drill press spindle/bearings arn't designed to take any sort of side load</TD></TR></TABLE>
that's a fact, can't argue with that.
jp
jp
i bet you get all kinds of crazy noises off that mill. A roughing mill on thin walled pipe. If you are having chatter problems just try to find a wooden dowl rod of some sort and shove it in the end of the pipe being notched and that will reduce chatter
