96 ~ 2000 TypeR LSD's will fit a 94 b series?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">any b-series </TD></TR></TABLE>
wrong.
gsr open diff is bigger then the rest (ls,gs....).
which happens to be the same size as the itr lsd.
otherwise you'll need to get a bigger final gear to make the lsd work.
wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8sirg »</TD></TR><TR><TD CLASS="quote">
wrong.
otherwise you'll need to get a bigger final gear to make the lsd work.</TD></TR></TABLE>
There is no demensional difference. The difference is the number of ring-gear bolts on an LS/b16 and the GSR/ITR.
An ITR diff/ring gear will drop into an S4C (99 Si) tranny, however. As far as the GSR tranny goes, a R diff will drop in...You can use the ring gear from the GSR diff if you find an LSD without a Ring-gear...
And many people sell an LSD without a ring-gear.
Good luck.
wrong.
Good luck.
Sliced Beard
Feb 10, 2004 05:27 AM
