For you guys who know how to get the turn signals to work after integra dash swap, I used the Civic
I have read in a write up that when you use the Integra dash harness, to get the turn signals to work you take the yellow wire from the grey plug and the yellow/black wire from the green plug and splice them together. Well i used the Civic dash harness and I dont have a yellow/black wire. What wires should I splice together to get my turn signals working. Or is there a different way. BTW, I have checked all my connections and wiring behind the cluster to make sure everything was good. Any help would be appreciated. Thanks.
wow browsing this board again really makes me want to get back into cars like i was a couple years ago..
I did this SEVERAL years ago and there should be a write up about how i did.. I do no remember but i hope you the best of luck when you get it done because it was a PIA for me because i was one of the first to do it i think...
It was a hell of a job, I would rather do an engine swap than do that again, it took me about 17 hours. But when you get behind the wheel, it is well worth it. Thanks for the reply though, I will go and read over those write ups some more.
streetracerof06
Jul 3, 2006 02:21 PM
streetracerof06
Jul 3, 2006 11:22 AM
streetracerof06
Jun 28, 2006 03:33 PM
rtiadnoh
May 6, 2004 12:34 PM
