Adding Air Condition: To those who have
How difficult was it? I've been reading through my chiltons manual and they don't cover AC because they say it's illegal unless you're certified or some bullshit.
I deliver food and when it rains, it ******* sucks my car fogs up so bad i have to turn on the heat, and you all don't know hot till it's 85* with the heat on high and the fan on high too . I can't deal with it anymore lol, i have a d16z6 93 dx hatch.
Now i'm the type of person who won't believe anything until i try it, so saying "oh you're a noob so don't try...etc". doesn't fly with me.
Any help is appreciated.
Cake walk
there is really only one way that all the parts bolt up. The hardest part is finding the components. You will want to take it to a shop to have it pressure tested to make sure all the seals are good and to have them fill it with the cold stuff
It is all plug and play.Try and find a comp unit out of a junk car or if you can still find it these things were dealer installed and came as a complete kit ($1,000). make sure and replace all the seals in the system if it a used unit. Google ac install on your make and model I found a copy on line of the OEM install manual for free walks you step by step through the install and gives you a comp parts list. I might still have the copy let me know if you can't find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">It is all plug and play.Try and find a comp unit out of a junk car or if you can still find it these things were dealer installed and came as a complete kit ($1,000). make sure and replace all the seals in the system if it a used unit. Google ac install on your make and model I found a copy on line of the OEM install manual for free walks you step by step through the install and gives you a comp parts list. I might still have the copy let me know if you can't find it.
I might as well wait till i swap in my b series then Can the lines from the d series AC stuff be used for b series? I'd appreciate it if you could let me know about that manual. If not it's cool too. Thanks fellas.
</TD></TR></TABLE>I might as well wait till i swap in my b series then Can the lines from the d series AC stuff be used for b series? I'd appreciate it if you could let me know about that manual. If not it's cool too. Thanks fellas.
mope
Mar 9, 2017 12:06 PM
BoostedSi
Nov 2, 2007 08:50 PM
jkoshy18
Aug 26, 2006 07:48 PM
