heard a weird sound..
Old Jun 28, 2006 | 11:12 AM
neyoLS's Avatar
Default heard a weird sound..
so i had to jump start my car..cause the battery is weak (barely starts the car)from sitting there forever and the cars been sitting there forever.. i reved to like 2.5rpm and it seems after i let go of the gas the car kinda looses power?? then i heard kinda like a pop..so i turned it off and turned myc ar back on and it seems okay.. my friend told me its the oil since its bad / old anything eles?? btw car was in neutral
Old Jun 28, 2006 | 10:04 PM
neyoLS's Avatar
Default Re: heard a weird sound.. (neyoLS)
anyone?? spark plug problem / oil ??
Old Jun 29, 2006 | 02:52 AM
Dilly's Avatar
a pop? probably back fire. but other than that, i dont know. sorry
Old Jun 29, 2006 | 08:58 AM
neyoLS's Avatar
Default Re: heard a weird sound.. (dillywong)
i was thinking backfiring too.. since my car felt weird but i have no cat and what soever so i'll prolly check my spark plugs later on
bump for more inof
Old Jun 29, 2006 | 01:36 PM
neyoLS's Avatar
TTT
Old Jun 29, 2006 | 02:07 PM
BrooX's Avatar
I would do a tune up and lof just to be safe. Afterwards it wouldn't hurt to check your charging system. See if your alternator/dizzy is up to par.
Old Jun 29, 2006 | 02:09 PM
LittleJohn1084's Avatar
where did the pop sound come from?
Old Jun 29, 2006 | 04:11 PM
neyoLS's Avatar
Default Re: (LittleJohn1084)
can't really say where my friend said up front... by the engine since i was in the car i just heard it... it wasn't REAL loud car seems fine i just dont wanna run into problems so i wanna check everything up...
what problems can i run into with out starting up the engine every once in a while while its just sitting there for lets say 10 months.. i try starting it up regularly.. and stuff i should of drove it around.. but yea lmk what could happen.. ie like oil siting too long pistons all that..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrooX &raquo;</TD></TR><TR><TD CLASS="quote">I would do a tune up and lof just to be safe. Afterwards it wouldn't hurt to check your charging system. See if your alternator/dizzy is up to par. </TD></TR></TABLE>
what is a LOF btw.. and yea im planning on gettin a tune up once i get it running
Old Jun 30, 2006 | 09:16 PM
neyoLS's Avatar
Default Re: (neyoLS)
help
Old Jun 30, 2006 | 11:46 PM
TRE_'s Avatar
definantly sounds like your plugs. replace them then see what happens. other things to check/replace fuel fitler(possibly clogged), rotor, cap, wires, ignitor. Replace the battery too
LOF is an oil/filter change.
Old Jul 2, 2006 | 04:34 PM
Default Re: (TRE_)
i'd run a compression test, plus you can replace your spark plugs. you sould try and start your car up more often, one to keep things like that from happening, and two so your tires don't develope flat spots from being in one place too long.
axionm1k
Jun 3, 2008 06:19 PM
cb7joba
Jan 1, 2007 11:11 AM
Mr.Hankey
Dec 14, 2006 05:27 PM
pennies_hatchie
Oct 29, 2002 01:38 PM
acuraLSSE95
May 17, 2002 05:39 AM
