is this normal?
Old May 16, 2002 | 03:32 AM
acuraLSSE95's Avatar
New User
Default is this normal?
I have an LS 95 with Intake and Exhaust, I've done all oil changes on time and only did the 30,000 mile service at acura and now the car has 40+k miles. In the past when I turn the engine on, it started with a strong "Vroom" sound and the car started on in like 1 to 2 seconds, but now it has a weaker "vroom" sound when I turn my car on. When I turn the key all the way, it drags for like 2 seconds before the car starts. and the starter sounds weak. Does anyone know what the problem is? Once it the car is on, it's working fine, no problems. It's just a weak start I'm complaining about. Could it be that I need new spark plugs or wires/ tune up?
thanks
Old May 16, 2002 | 03:55 AM
OneFastLS's Avatar
Default Re: is this normal? (acuraLSSE95)
Get some new spark plugs and wires. Then check the distributor cap, and also your alternator. I would also reccomend just getting a general tune up. This doesn't sound like a serious problem, but you definitely want to take care of it so that one day that car doesn't start when you turn the key.
Old May 16, 2002 | 04:48 AM
BSQ's Avatar
BSQ
It sounds like your battery may be becoming weak. I pretty sure that most auto parts store will check your battery for free. Do you still have the original battery?
Old May 17, 2002 | 05:39 AM
New User
Default Re: is this normal? (BSQ)
thanks. I was also wondering if it could have been my fog lights. I had those lights install not too long ago and I have been using it alot at night along with the headlights.
PaulMc
Mar 7, 2013 08:01 PM
wiredzone
Dec 18, 2009 02:46 PM
po0tie
Feb 17, 2008 09:46 AM
2ndName
Apr 26, 2006 05:23 PM
grizoove
Apr 1, 2003 10:10 AM
