End Link Problem?? I Think.
Has anyone had problems with after market end links (progress) causing a 'clunking' sound in the rear suspension??
I upgraded to a Progress rear sway bar and Progress end links. Since the install I've been getting a loud 'clunk' from the rear drivers side when ever I hit a bump in the road. Not just big bumps either, small one's as well.
HELP. ANYONE???
HELP. ANYONE???
Well first off - check your strut tower in the back. The nut might not be tight enough.
Also, is it squeaking also? because that would indicate a blown strut.
Did u use bushings in the end link? If you did - and everything's tight, it shouldn't clunk.
I had that same problem with OEM endlinks and a Progress bar.
This should help--https://honda-tech.com/zerothread?id=1474587
How tight is "tight enough" for the top nut at the rear strut tower??? can it be over tightened??
Bushings in the end links??? Explain??
Hawk, has the tape around the bolt held up???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barriecarson »</TD></TR><TR><TD CLASS="quote">
Hawk, has the tape around the bolt held up???</TD></TR></TABLE>
Absolutely
, packing tape is almost rock hard if it's wound perfectly tight. My suspension is totally quiet now.
Absolutely
Steve91
11
May 20, 2002 10:45 PM
