stcorsa camgear users - am i off a tooth?
i know some of you guys are using stcorsa camgears. am i off a tooth? or is this normal for stcorsa cam gears?
Modified by an2ny888 at 3:14 AM 6/29/2006
Well from your pictures it looks like the gears have already been adjusted which would mean that those would no longer line up at top dead center.
would that make a difference? i was under the assumption that it should line even if the cams weren't at 0,0.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">would that make a difference? i was under the assumption that it should line even if the cams weren't at 0,0. </TD></TR></TABLE>
Actually you're right. Its too early.
Are you sure you're actually at TDC and don't just need to rotate the crank a small amount more?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">you need some sleep hehe
nah i'm sure it's dead on at the tdc mark</TD></TR></TABLE>
I only got 2 hours last night and about the same the night before. I'll let someone else try to help you since I'm just getting nowhere.
nah i'm sure it's dead on at the tdc mark</TD></TR></TABLE>I only got 2 hours last night and about the same the night before. I'll let someone else try to help you since I'm just getting nowhere.
turbo boost
Jun 17, 2006 01:41 PM
