Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheel and tire setup ?? for crx
Old Jun 27, 2006 | 09:16 PM
D3U1LT's Avatar
Default Wheel and tire setup ?? for crx
14inch wheel and 50series tire setup ideal for track?
Reason I ask is the crx doesnt have much space to acomidate a bigger wheel without being all jacked up. so I was wondering this. Would it take the benifits of the rolling diameter away? I.E. Volk 14" Te-37 and some 1950/50/14 azenis... lmk thanks.
Old Jun 27, 2006 | 09:53 PM
vietnameeh's Avatar
i think they only make a 195/60-14 in the 615s
Old Jun 28, 2006 | 10:39 AM
Targa250R's Avatar
be professional
Default Re: (vietnameeh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnameeh &raquo;</TD></TR><TR><TD CLASS="quote">i think they only make a 195/60-14 in the 615s</TD></TR></TABLE>
Correct, 195/60-14 is the only current 14" Azenis size. 185/60-14 will be available some time in September.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D3U1LT &raquo;</TD></TR><TR><TD CLASS="quote">Reason I ask is the crx doesnt have much space to acomidate a bigger wheel without being all jacked up.</TD></TR></TABLE>
I don't know what you're talking about . . . I ran 195/60-14 RT-215 Azenis for a long time, then 205/50-15 RT-215s, and I am currently running 225/45-15 Hankook RS2-Z212s. My car is lower than stock height.
Old Jun 28, 2006 | 11:05 AM
vietnameeh's Avatar
Default Re: (Targa250R)
hey how is that set 225-45-15
better improvement over the 205s?
Old Jun 28, 2006 | 11:20 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnameeh &raquo;</TD></TR><TR><TD CLASS="quote">hey how is that set 225-45-15
better improvement over the 205s?</TD></TR></TABLE>
The old 205/50-15 Azenis RT-215 was so wide that it was damn near a 225 already (I measured just a hair under 220mm on a 7" wheel). Grip is comparable to the RT-215 but the sidewalls are noticeably softer. I don't know how an RT-615 compares because I haven't been able to get a hold on any yet.
Old Jun 28, 2006 | 12:04 PM
D3U1LT's Avatar
50series on 15's will be fine on a fairly low rex? without rubbing and binding in turns... what about a 205 tire?
Old Jun 28, 2006 | 12:05 PM
D3U1LT's Avatar
Default Re: (D3U1LT)
and for a 14" 60series tire is this too much tire for the track?
Old Jun 28, 2006 | 12:39 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D3U1LT &raquo;</TD></TR><TR><TD CLASS="quote">50series on 15's will be fine on a fairly low rex? without rubbing and binding in turns... what about a 205 tire?</TD></TR></TABLE>
Yes, this is what I have on my car and I put it on the track. I have yet to rub anywhere on the track at VIR, RA, CMP, or Roebling.
I actually rubbed more in DrDisco69 HF totally stock, stock suspension and stock 13" steelies rubbed all over VIR and I have never rubbed on my 205/50/15's with lower than stock by about inch or two.
Old Jun 28, 2006 | 01:32 PM
Targa250R's Avatar
be professional
How low is it? What is the wheel offset? What are the spring rates and sway bars?
Old Jun 28, 2006 | 02:47 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D3U1LT &raquo;</TD></TR><TR><TD CLASS="quote">and for a 14" 60series tire is this too much tire for the track?</TD></TR></TABLE>
I run 195/60-14 215 Azenis on my Civic. I'm not sure what "too much tire for the track" means, but it's a slightly smaller overall diameter compared to the stock 185/65-14's.
If you're asking if a 195/60-14 has too much sidewall for the track, well the answer is no, not really. Sidewall stiffness has as much to do with the size as it does the brand. Azenis tend to have fairly stiff sidewalls as compared to other performance tires.
Unless you're competitively racing, I'd worry less about what the best setup for the track is, and more about just going to the track to learn.
Old Jun 28, 2006 | 04:14 PM
D3U1LT's Avatar
Default Re: (nonsense)
thanks
shotgun2224
Aug 18, 2007 10:03 PM
Touch
Jul 2, 2006 02:34 PM
wfocrx
Jun 14, 2006 04:21 AM
b20integrapower
Mar 18, 2006 08:28 AM
the.hamburglar
Nov 15, 2005 08:28 AM
