Is this cracked injector still good.
Old Jun 27, 2006 | 05:28 PM
realis9's Avatar
Default Is this cracked injector still good.
I got this from a H-T member today. Can it still work?
Old Jun 27, 2006 | 07:21 PM
realis9's Avatar
Default Re: Is this cracked injector still good. (realis9)
^ does anyone know?
Old Jun 27, 2006 | 07:26 PM
JjuuN R's Avatar
why would you even chance running that??
Old Jun 27, 2006 | 08:34 PM
itr1244's Avatar
Default Re: Is this cracked injector still good. (JUN.R)
return it back and buy my MINT one
Old Jun 27, 2006 | 09:08 PM
realis9's Avatar
seller told me it would work that is why i'm asking. I hope he refund my money.
Old Jun 27, 2006 | 10:53 PM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">seller told me it would work that is why i'm asking. I hope he refund my money.</TD></TR></TABLE>
i would not run that in my car if i were u
and i hope he refunds your money too if he does. hit me up
Old Jun 27, 2006 | 10:56 PM
Dat1BVtecN's Avatar
Default Re: Is this cracked injector still good. (itr1244)
freak no that isnt reusable, i know from first hand experience, i got 4 obd1 injectors for sale if ya want, no cracks either haha, let me know
Old Jun 27, 2006 | 11:08 PM
itr1244's Avatar
Default Re: Is this cracked injector still good. (Dat1BVtecN)
if you are looking for stock itr injectors. i've got them
Old Jun 27, 2006 | 11:51 PM
SPOON_BeIgHtEeNsEe's Avatar
dood u people dont know ****... its just a cover... injector will work FINE... i have ran many injectors with the whole shell cracked off without a problem... as long as the needle inside is NOT bent its OK to run... but if u want a refund i have no problem giving it back...
Old Jun 28, 2006 | 03:12 AM
Reid's Avatar
Global Moderator
Default Re: Is this cracked injector still good. (SPOON_BeIgHtEeNsEe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">dood u people dont know ****... its just a cover... injector will work FINE... i have ran many injectors with the whole shell cracked off without a problem... as long as the needle inside is NOT bent its OK to run... but if u want a refund i have no problem giving it back...</TD></TR></TABLE>
So you would risk having the cover fall off in the combustion chamber?
Old Jun 28, 2006 | 04:42 AM
splitime's Avatar
Default Re: Is this cracked injector still good. (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">So you would risk having the cover fall off in the combustion chamber? </TD></TR></TABLE>
You remove the cover.... its just a cover
You can get replacement covers from some of the injector cleaning guys if you want. But its just a shield to protect the pintle while the injector is out of the car.
Doesn't affect injector at all.
Old Jun 28, 2006 | 05:05 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Is this cracked injector still good. (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">You can get replacement covers from some of the injector cleaning guys if you want. But its just a shield to protect the pintle while the injector is out of the car.
Doesn't affect injector at all.</TD></TR></TABLE>
I'm sure it wouldn't affect the function of the injector.
But personally I wouldn't put that in my car. I don't want any broken plastic bouncing in the combustion chamber.
Old Jun 28, 2006 | 05:31 AM
SPECR's Avatar
Default Re: Is this cracked injector still good. (Wai)
You can easily have the injectors serviced and rebuilt for as little as $12 a piece. They'll even flow test it for you.
http://www.cruzinperformance.com/injsteps.html
Old Jun 28, 2006 | 05:06 PM
ArmyGreenITR's Avatar
Default Re: Is this cracked injector still good. (SPECR)
How is this ITR related ?
I wouldnt risk running that.
Old Jun 28, 2006 | 10:25 PM
Default Re: Is this cracked injector still good. (ArmyGreenITR)
its not hard to remove the whole shell... but im gonna send him another injector
Old Jun 29, 2006 | 11:58 AM
Rory Breaker's Avatar
You can just rip off the broken piece of the pintile cap and run it....not a big deal at all.....
Old Jun 29, 2006 | 02:37 PM
01usjdmr's Avatar
Good luck with that. Hell why did honda put that on there anyway? Don't run that injector. It will effect the spray pattern.
Old Jun 29, 2006 | 07:40 PM
vtec.dc2's Avatar
whether that part requires repair or not.. if you suspect too much milage/abuse on these injectors.. have them tested/cleaned/balanced before installation.
Old Jun 30, 2006 | 04:03 AM
Default Re: (01usjdmr)
I dont know...why does Honda put retaining screws on the rotors?
It does not affect the "spray pattern" at all. The cap is there to protect the pintle. If you took an injector out of your motor now and ripped off the cap and put it back in there would be no difference.
Old Jun 30, 2006 | 05:33 PM
01usjdmr's Avatar
Your right Honda R&D must suck.
Old Jul 1, 2006 | 01:13 AM
an2ny888's Avatar
what kind of injector is that? doesn't look like an itr injector to me, appears to be a obd1 injector
Old Jul 1, 2006 | 12:54 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure it wouldn't affect the function of the injector.
But personally I wouldn't put that in my car. I don't want any broken plastic bouncing in the combustion chamber.</TD></TR></TABLE>
thats the only thing.. the design of the injector is build with that shield to aim the spray of fuel out torwards the air flow, and enter the combustion chamber.
if you HAD to use it.. i would litterally break off the brittle part of that sheild, and then put it in. i too wouldn't want that plastic goin into my motor..
now, is it performancely bad? the reason i know alittle about this, i had DSM 450's on my D16Z in my old hatchback boosted on 11PSI, and it was tunned on the dyno wiht a 12.5 AFR. so that shield didn't affect it that much.. and i had 2 that were broken.
Old Jul 1, 2006 | 06:53 PM
ayougo's Avatar
bottom line, its still a good injector and can be used if the housing is taken off...BUT... if your a perfectionist and you have the ability to get it taken care of, then i would do so.
Old Jul 2, 2006 | 05:26 AM
Default Re: Is this cracked injector still good. (01usjdmr)
...or you can just sit back with no understanding of what, why, or how and say "honda r&d made it so its mandatory"...that works too.
This forum is for answers and intelligent discussion, not for ignorance and logic-less conclusions. If you dont agree, and you think the cap serves another purpose and its a good idea to use it, then by all means shoot your story, otherwise, youre just wasting everyones time.
Old Jul 2, 2006 | 08:16 AM
RPRacing's Avatar
like others have said, That piece does not affect injector performance. Check the tip to make sure it was not affected though. Break that piece off and be happy.
If the seller will send you a new one, cool. He is a nice guy. thats like receiving an exaust manifold gasket and having it bent or missingg a rivet. Makes no difference when the motor is together, but when you knnow its not perfect, you bitch
ilovemyeg
Honda Motorcycles
13
Nov 9, 2008 08:32 PM
Jaysun
Northwest (Sales)
13
Sep 26, 2007 05:07 PM
Heavy Pee
12
Sep 4, 2006 12:47 PM
