Anyone tried the Prestone flush kit for the CRX
I am trying to get this piece of **** to work and it seems pretty weak. There is water spraying every where (all over the dizzy), do your really leave it like that for 5 minutes? also the block drain bolt has tig welded itself to the block, so thats no use. I am going to try that BAR's stop leaks to see if I can get my D15 to last a few more weeks (not compatible with coolant it says so I have to flush it), it eats about an inch of coolat every 30-60 miles.
help me por favor
help me por favor
well, for the record, BARs stop leak definately made a difference, I am not sure if it is bulletproof but I have kept it under 3k since then, the coolant is 1/2" above the fill line and I have driven about 150-200 miles. I had to refill it a little bit after the air pockets dissapated the day after, other than that it seems solid
The stop leak is horrible for the engine, I have seen it close up water jackets and cause engines basically the implode
well good thing it is just a d15b2 with 230k, It says on the bottle that if it is combined with coolant it will clog things up. You have to flush it before and after it cures
CoolRedXylophone
Apr 30, 2006 06:59 AM
