FS: OBD I to OBD II adapter
To clarify things, the adapter harness goes between the connections found inside the passenger side kick panels that once plugged into the old ecu. It allows you to plug a OBD II ecu in the car with a B-series swap(OBDII).
I made it myself. It will work but you still need to run four wires to the engine harness. A 92-94 civic (OBD1) does not have a knock sensor, crank angle sensor, or a secondary butteryfly.
ShawnR
Sep 22, 2007 03:18 PM
guyuenvy
May 16, 2002 12:27 AM
