turbo for ls??
i'm tring to figure out which turbo will be the best for a built ls motor. this will be my project car and will be use only on the track. what do you guys turbo do you guys think i should go with? goal is to hit low 10's and hopefully high 9's i seen people using the drag 3 turbo and was thiking about that. what do you guys think?? and where can i get a good head gasket for this?
I think for those sorts of times you should call some tuners that have a lot of experience with turbo setups and ask them what they think. You will definitely need hondata or an equivalent ems, and you may need a bigger turbo than the one that comes with the drag or other kits. Your goal will take a lot of time, work and money, and probably a few engine blocks too. But most of all you need to find someone that knows their s$%t.
Good luck
Good luck
thanx guys. rite now i'm working on builting the bottem end and looking for a place to built my block to hold the boost. yea it'll take awhile and alot of tuning but it'll happen
