installing intake gasket (d16z6)
Old Jun 26, 2006 | 11:47 PM
stwano's Avatar
Default installing intake gasket (d16z6)
On the old gasket there was metal that went around the coolant port but the new gasket i got doesnt (felpro). but it does have a little metal around a circle port that looks to go nowhere. Is the metal around the coolant port necessary?<?<? and is there a special procedure when tightening the manifold down?<?<?
Old Jun 26, 2006 | 11:59 PM
Lookinaround's Avatar
New User
Default Re: installing intake gasket (caliscrilla)
Are you putting the intake manifold on or the throttle body?
If there was a gasket there originally then im sure you need something there. When i replaced the IM and gasket on my old gsr i just slapped it on there and put it all back together.
Shoot some liquid gasket on there and put her back together!
Old Jun 27, 2006 | 12:38 AM
stwano's Avatar
Im installing an intake manifold gasket
the new gasket doesnt have metal around the coolant port but the old one does. is the metal around the coolant port neccessary???
I wanna make sure i have the right gasket
I just dont want to do everything to find out i put the wrong gasket in
Old Jun 27, 2006 | 02:50 AM
fmrprojects's Avatar
it should be fine. use a razor blade and get off all the old gasket and make sure the sufaces on both the head and intake manifold are clean before reinstalling. tighten ffrom middle-out
extensioncordy
Jan 16, 2007 04:03 PM
actionfigure
Jan 7, 2007 07:06 AM
dpine
Sep 30, 2006 05:35 PM
OrangeBoost
May 9, 2006 04:34 PM
