Honda S2000 Honda S2000
Mugen Thermostat
Old Jun 26, 2006 | 09:53 PM
nikboca's Avatar
Default Mugen Thermostat
Does anyone have intallation instructions for this.
Old Jun 26, 2006 | 09:57 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Mugen Thermostat (nikboca)
Service manual has pictures.
Remove thermostat cover (2 bolts, connects to lower radiator hose, by driver side motor mount.
Replace thermostat. Replace thermostat cover gasket.
Reinstall thermostat cover.
Old Jun 26, 2006 | 11:49 PM
Moemers's Avatar
Default Re: Mugen Thermostat (FR-MOB: Projekt)
and what, pray tell, is this thermostat good for.
Old Jun 27, 2006 | 05:19 AM
mellowhead's Avatar
Default Re: Mugen Thermostat (Moemers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moemers &raquo;</TD></TR><TR><TD CLASS="quote">and what, pray tell, is this thermostat good for.</TD></TR></TABLE>
I guessing that since it is Mugen, it doesn't really matter...
Old Jun 27, 2006 | 05:36 AM
Luder94's Avatar
Default Re: Mugen Thermostat (mellowhead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead &raquo;</TD></TR><TR><TD CLASS="quote"> I guessing that since it is Mugen, it doesn't really matter...</TD></TR></TABLE>
"Reading is hard......searching is harder"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inline4 &raquo;</TD></TR><TR><TD CLASS="quote">
We recommend the use of this thermostat to aid in the effiency of your vehicles cooling system. It prevents engine power loss by minimizing rapid water-temperature rises under extreme conditions. The Mugen thermostat opens up at a lower temperature than a factory unit allowing the coolant to flow through your engine sooner reducing coolant temperature.</TD></TR></TABLE>
Old Jun 27, 2006 | 06:08 AM
negcamber's Avatar
Here is a write-up on the thermostat install (also header install):
http://www.s2ki.com/forums/ind...07050
Note that getting to the thermostat is a bitch with the intake manifold in place. But removing the intake manifold is also a bitch...but if you remove the manifold you can do the Hondata insulating gasket as well (which arguably is a better mod than the thermostat alone).
Old Jun 27, 2006 | 09:26 AM
* B A N N E D *
Default Re: (negcamber)
You can get it from the bottom if you're sneaky.
Old Jun 27, 2006 | 09:27 AM
kane.s2k's Avatar
Be sure you have the little hole at the top.
CARMA_626
Mar 17, 2008 07:53 PM
Beau Gotti
Feb 27, 2006 10:21 AM
ripclaw337
Oct 2, 2005 08:22 PM
Mr. JDM-GSR
Jan 8, 2005 04:04 PM
belchR
Apr 16, 2003 10:22 AM
