Have a problem with my R 00-360
Sup brothers ! I have a little problem that I believe you guys can help me out with. When my car is at a standing stop everytime I hit a red light , the car seems to shake. I mean you can really feel it. Any suggestions on what the problem is. Also I been bringing the car to a shop whos been putting chevron 10-30 into the car. I know thats cheap shi## but would that be the problem. Also what kind of oil should I use.
Do you mean it shakes for just a second or like throughout the time you're at a stop? Do you look at your rpm and seee if it dips down low and then back up to normal?
No the RPM doesnt go down and back up. It just stays still but the car seem to shake lil' bit. Its enough to notice. I dont know what it is.
No need to use the HAMP filter. I recommend using the usual Honda filter.
Mobil 1 is better than the chevron. If you change your oil very often I suggest just using Castrol GTX.
how often should i change it if i use castrol. i change my oil every 2500-3000 miles.also is castrol gtx ure usung syntetic or normal. thanks
im sure that you bought the car new!
well if it does it all the time , then have the dealer check it out for you .
but make sure to also watch your rpm gauge to see if went your at a stop that the idle is not lower then what should be !
thanks guys! i got it used but it came with warranty so im sure i need to get it looked at. also should i take out the aem cai or leave it. thats my only mod.
also what should the rpm idle be at normally? and should i use 10-30 or 10-40 oil.sorry for all these damn Q's guys.haha. thanks
some of then could be punks
whats up 360 jr. thanks for u guys help. but u guys think i need to remove my aem cai or leave it when i bring it to the dealer?
Better safe than sorry even though it is CARB legal. You never know what the dealer is gonna say. One of my friends has a chipped S4. Most Audi dealerships will void your warranty for that, but the place he goes to "recommended" he get the chips. He goes there to get service, no problem. Go figure.
[Modified by acuracing, 3:19 AM 4/18/2002]
