water in engine?
Old Jun 26, 2006 | 08:42 PM
bren2065's Avatar
Default water in engine?
I have a cold air intake on a 96 honda civic EX and went through some heavy water and the car started running real shitty but it ran better after the rain cleared of the road but the oil had white spots in it and the car still runs but not as good i think there is water in my engine any suggestions would be appreciated
thx
Old Jun 26, 2006 | 08:53 PM
sol2hatch's Avatar
Default Re: water in engine? (bren2065)
if water got sucked up, and it is alright now, then i think you would be alright. Consider yourself lucky. Did you go through a deep puddle?
Old Jun 26, 2006 | 09:05 PM
komat's Avatar
Default Re: water in engine? (sol2hatch)
change your oil asap
put new plugs while you at it
FalkenSiR's Avatar
Default Re: water in engine? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">change your oil asap
put new plugs while you at it</TD></TR></TABLE>
Old Jun 26, 2006 | 09:17 PM
BuiltforSin's Avatar
sounds like your a lucky devil.. check your oil to be safe
Old Jun 27, 2006 | 08:30 AM
bren2065's Avatar
i shortened my intake but how the hell do you have a cold air intake like that and prevent water gettin in? im gonna change my plugs and oil then i guess
im missing the wheel well lining of plastic i think that might have prevented some of the water i was down in OC MD this weekend and it was raining like a mother f***
Old Jun 27, 2006 | 09:18 AM
sickvic83's Avatar
BYPASS valve, its designed to not allow water in. Its well worth the 50 bucks new.
Old Jun 27, 2006 | 09:49 AM
cambopheonix56's Avatar
Default Re: water in engine? (sickvic83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickvic83 &raquo;</TD></TR><TR><TD CLASS="quote">BYPASS valve, its designed to not allow water in. Its well worth the 50 bucks new. </TD></TR></TABLE>
Doesnt work unless the filter is completely submerged.
Old Jun 27, 2006 | 10:28 AM
MonkeyBoy668's Avatar
Default Re: water in engine? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">Doesnt work unless the filter is completely submerged.</TD></TR></TABLE>
Yes and no (I saw a demonstration video where it wasn't completely submerged and the bypass opened - though it was very close), but you have to admit that - no matter what - having one is better than not having one at all.
You should have the fenderwell liner installed, if for no other reason than to keep all the road debris from hitting your filter. If you want to get cold air into that area, baffling/piping works wonders.
91dxhatchy
23
Jul 19, 2011 02:09 AM
pr1286
Aug 20, 2010 10:33 PM
Mr_Moos
Jul 20, 2007 05:20 PM
mikeycivic
15
Jul 17, 2006 12:52 PM
accord03coupe
Jun 8, 2004 10:31 PM
