iacv pinout fix (yes another thread on it)
Old Jun 26, 2006 | 05:26 PM
alacard's Avatar
Default iacv pinout fix (yes another thread on it)
i have a 98 dx with a p75 ecu and a y8 intake mani...i know i need the y8 tb, the y8 iacv, and the 2 wire plug...i have all that...my question is with the pinouts on the ecu...i read the iacv fix from https://honda-tech.com/zerothread?id=1171263 ...but when it talks about the pinouts its referring to the 99-01 ecus...i dont think the 92-95 ecus even have a b23 pinout (which it talks about)...can anyone help me out on what i need to do for this?
thanks in advance.
Old Jun 26, 2006 | 11:54 PM
alacard's Avatar
Old Jun 27, 2006 | 05:08 PM
alacard's Avatar
Default Re: (alacard)
no one can help me out with this?...i figured it would be a semi-simple question
Old Jun 27, 2006 | 05:33 PM
hondaguyef's Avatar
B23 is a pin location on the ECU plug not the ECU itslef. Understand?
Old Jun 27, 2006 | 11:42 PM
alacard's Avatar
Default Re: (hondaguyef)
so in this picture:
those are the right diagrams for the pinouts for my p75 ecu?
Old Jun 28, 2006 | 02:48 AM
hondaguyef's Avatar
Only if your P75 is obd2b. Look below the pic of the ECU, That is as if you are looking at the back of the cabin side harness that plugs INTO the ecu (which is where the pins have to be switched).
Phil
Old Jun 28, 2006 | 08:45 AM
alacard's Avatar
see...thats what im saying...the p75 is obd1...so i dont know what to look off of for switching the pinouts
Old Jun 28, 2006 | 11:38 AM
alacard's Avatar
bump
Old Jun 28, 2006 | 12:52 PM
BignevadaBoB's Avatar
if you do not have a obd2b to obd1 jumper harness that ecu cannot be plugged in. if you do have the jumper harness all you have to do is repin the wires on the plug side then all is good.
as for the diagram, the pic of the ecu is just to refrence where plugs a, b, or c go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Only if your P75 is obd2b. Look below the pic of the ECU, That is as if you are looking at the back of the cabin side harness that plugs INTO the ecu (which is where the pins have to be switched).
Phil</TD></TR></TABLE>
Old Jun 28, 2006 | 01:18 PM
alacard's Avatar
Default Re: (BignevadaBoB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BignevadaBoB &raquo;</TD></TR><TR><TD CLASS="quote">if you do not have a obd2b to obd1 jumper harness that ecu cannot be plugged in. if you do have the jumper harness all you have to do is repin the wires on the plug side then all is good.
as for the diagram, the pic of the ecu is just to refrence where plugs a, b, or c go.</TD></TR></TABLE>
no..i have a conversion harness...its all setup and running...i just have to fix the iacv so it can idle...but anyways...so if i go off of that diagram it'll be good?
thanks for the replies
Old Jun 28, 2006 | 01:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the replies</TD></TR></TABLE>
yup, just repin your original harness accoding to diagram
Old Jun 28, 2006 | 02:08 PM
alacard's Avatar
alright...sounds good...thanks.
Old Jun 28, 2006 | 02:20 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">alright...sounds good...thanks.</TD></TR></TABLE>
You understand now? The repinning has NOTHING to do w/ your conversion harness or the ecu. Just the OE cabin side ECU harness.
Phil
Old Jun 28, 2006 | 09:47 PM
alacard's Avatar
so its just the wiring thats come out of my car...not the harness or the ecu.
yeah...got it...thanks for the help guys
bcm0529
10
Aug 29, 2017 07:13 AM
n_senn
21
Aug 3, 2011 07:30 AM
h22boii
Oct 4, 2009 03:26 PM
dxcivicsi
Jun 1, 2009 09:17 PM
