Clutch Kit OR Clutch Master Cyl. and Slave Cyl. install?
Old Jun 26, 2006 | 05:08 PM
turboME's Avatar
Default Clutch Kit OR Clutch Master Cyl. and Slave Cyl. install?
I have a '95 Civic Ex 1.6 and need a new Clutch Slave Cyl. and a Master Cylinder. Should I have just these parts replaced for an estimated $309 (tota) or should I just get a new clutch kit for $197 (Clutch Kit Exedy OEM) + installation? Any help or information is greatly appreciated. Thanks in advance.
Old Jun 26, 2006 | 05:52 PM
sicones's Avatar
Default Re: Clutch Kit OR Clutch Master Cyl. and Slave Cyl. install? (turboME)
well either you need a new slave and master or a new clutch, which one is it, and when doing the slave/master it dosent involve droping the tranny (for clutch)
you can do the slave and master cylinder yourself for under $100, and a clutch for the cost of the clutch
Old Jun 26, 2006 | 05:56 PM
turboME's Avatar
Default Re: Clutch Kit OR Clutch Master Cyl. and Slave Cyl. install? (sicones)
I was told i need a new master cyl And a slave cyl. (had it looked at by Goodyear)
i dont have many tools to work on it myself. Would you say a non-mechanic person could install these two parts with relative ease?
Modified by turboME at 11:28 PM 6/26/2006
jdmsiR20's Avatar
yup...
what exactly is the problem that you're having?
Old Jun 26, 2006 | 06:24 PM
sicones's Avatar
Default Re: Clutch Kit OR Clutch Master Cyl. and Slave Cyl. install? (jdmsiR20)
there pretty easy to install, the biggest pain is the getting to the master cylinder under the dash and adjusting the arm, a trained monkey can install a slave cylinder
MasterLink4253
Jun 9, 2014 07:22 AM
ohsnapzafingcu
May 16, 2011 04:30 PM
phantom_sol
Oct 8, 2003 08:14 PM
lude97dude
May 19, 2003 02:32 PM
dnt94civic
Feb 28, 2003 03:28 AM
