max tire size on VX wheels
Old Jun 26, 2006 | 04:01 PM
wannabEG6's Avatar
Default max tire size on VX wheels
What do you guys think the widest tire i can fit on my stock 13" VW wheels?
they are sssoo light and i want to use them for drag races, but they are on the skinny side.
Old Jun 26, 2006 | 04:44 PM
VX's Avatar
VX
Default Re: max tire size on VX wheels (wannabEG6)
i've been using 185/70/13's on em for the past 2.5 years daily driven w/o any problems.
maybe 195 max? i'm not sure though.
Old Jun 26, 2006 | 04:48 PM
MattP's Avatar
Depends what you're using them for, and what tires you are using. I've seen 225/50R13 Hoosiers on that size rim for autocross, and have heard of 225/45R13 Hoosiers for the same reason. Makes sense for a stock class car with a lot of body roll. Not sure what size drag slicks would fit.
Old Jun 26, 2006 | 06:22 PM
old man neri's Avatar
If this is just for a street car: GET THE TIRE THAT IS THE CORRECT SIZE FOR YOUR CAR. Wider is not better.
What's your story; what car do you have, what is the use for this car....etc?
Cheers.
Old Jun 26, 2006 | 08:06 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: max tire size on VX wheels (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">what is the use for this car....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannabEG6 &raquo;</TD></TR><TR><TD CLASS="quote">i want to use them for drag races</TD></TR></TABLE>
Old Jun 27, 2006 | 04:40 AM
Default Re: max tire size on VX wheels (nsxtasy)
I stand corrected, apparently reading and comprehension does, infact, 'own' me.
Modified by old man neri at 2:05 PM 6/27/2006
Old Jun 27, 2006 | 09:47 AM
wannabEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">I stand corrected, apparently reading and comprehension do, infact, 'own' me. </TD></TR></TABLE>
thats ok, it ownes me to sometimes.
I was thinking about some of these tires
http://ssl.delti.com/cgi-bin/r...co=35
they are some of the only semi-compatition tires i can find in 13's
Old Jun 27, 2006 | 10:06 AM
Yoko makes some competition tires. Check out tirerack.
Old Jun 27, 2006 | 11:38 AM
MattP's Avatar
Most autocross and road racing tires make pretty lousy drag tires due to their stiff sidewalls. Why not get some wider wheels and run slicks?
Old Jun 27, 2006 | 03:08 PM
wannabEG6's Avatar
because i don't want to spend the money on new wheels if i don't have too, expecialy then these ones are sssoo light!
Old Jun 27, 2006 | 11:07 PM
SimplyTron's Avatar
Im in the same boat. I have VX wheels and am running Yoko. road racing tires for drag. The sidewall blows but theyre soft compound and better than street tires. The tires are 185 and seem to have alot of room left. 205s seem possible for drag only. 195 to be conservative. Ive been lookiing for DR's or slicks to fit these wheels for a long time with no luck. Good luck, maybe someone will chime in with an answer.
Old Aug 1, 2006 | 11:17 AM
EF-Honda91's Avatar
Dang that dissapoints me i have VX wheels too and i to was wondering how wide enough tire would be say u had 900hp is there a tire that can hold it?
Old Aug 1, 2006 | 11:20 AM
EF-Honda91's Avatar
and incase i did not make myself clear the widest tire i wonder what could fit is a 91hatchback drag radials that is street/track use.
MDM
Apr 13, 2012 12:09 PM
civic_kid0104
Apr 4, 2011 11:29 AM
jamescb77
Sep 14, 2007 05:54 AM
memorybox
Feb 24, 2007 12:57 PM
KiDSoL
18
Jan 16, 2004 11:40 AM
