everytime I take out the battery is my ECU reset?
I took out the battery to get it recharged and now my idle is all weird and cuts out. Last time I took out the battery the same thing happened. Idle would drop down and sometimes die
so then how would you change the battery???.......I heard its good to reset it after dropping in a cai or other mods to improve gas mileage, am I right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 »</TD></TR><TR><TD CLASS="quote">so then how would you change the battery???.......I heard its good to reset it after dropping in a cai or other mods to improve gas mileage, am I right?</TD></TR></TABLE>
when u change the battery it will reset, unless you connect to a backup battery while replacing the battery but thats just stupid and waste of time if youre trying to avoid reprogramming your radio presets
yes, you should reset the ecu whenever you add or remove something like i/h/e/etc....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign »</TD></TR><TR><TD CLASS="quote">yes, you should reset the ecu whenever you add or remove something like i/h/e/etc....</TD></TR></TABLE>
That's a myth that won't die.
F$CK my car runs like **** now. Idle used to be perfect now it's almost dying when I come to a complete stop. I hope the ECU adjust soon because this really sucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piggydog »</TD></TR><TR><TD CLASS="quote">F$CK my car runs like **** now. Idle used to be perfect now it's almost dying when I come to a complete stop. I hope the ECU adjust soon because this really sucks</TD></TR></TABLE>
are you just kidding?
I dont think that just because you reset your ECU your car is going to die. Maybe you have the wrong ECU?
seems like everything is screwed on tightly. Idle is all weird now. I will try and tighten it when I get home
DrewkCarrigan
Honda S2000
Mar 13, 2006 04:51 PM
towns
Dec 9, 2004 03:30 PM
bigslimdog
Mar 30, 2004 03:07 PM
