LS Turbo project
Old Jun 25, 2006 | 10:35 PM
sleeplsm's Avatar
* B A N N E D *
Default LS Turbo project
What size turbo should i get if in plan to keep stock internals and daily drive
Old Jun 26, 2006 | 12:07 AM
Adambomb's Avatar
I'm also going boosted on a stock ls, with minor mod's to the fuel system. Rev Hard Stage 2 @ 8 lb boost.
Just keep it under 9 lbs psi and don't floor the pedal at every light and you should be okay.
Also, make sure you get a good clutch to keep your gears from slipping.
Old Jun 26, 2006 | 12:14 AM
teg racer 877's Avatar
Default Re: (AdamO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamO &raquo;</TD></TR><TR><TD CLASS="quote">I'm also going boosted on a stock ls, with minor mod's to the fuel system. Rev Hard Stage 2 @ 8 lb boost.
Also, make sure you get a good clutch to keep your gears from slipping. </TD></TR></TABLE>
Im doing ls-t also, you can take it higher than 9psi, psi dont matter, run as much psi as you need to reach your goal, its all in the tuning, and a good clutch dont keep the gears from slipping, it keeps the clutch from slipping
Oh: to answer ur question, get a t3t4 50, 57 or 60 trim, but if u got money go with a garrett gt seires turbo, or precision and search also
Old Jun 26, 2006 | 05:45 PM
Adambomb's Avatar
Default Re: (teg racer 877)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 &raquo;</TD></TR><TR><TD CLASS="quote">
Oh: to answer ur question, get a t3t4 50, 57 or 60 trim, but if u got money go with a garrett gt seires turbo, or precision and search also </TD></TR></TABLE>
Yeah, you can always push up the PSI, but just have to re-inforce the internals eventually. I'm not saying you can't go over 9 psi, but if you're using a bone stock engine and racing it with that much boost, it's not going to last long.
Old Jun 26, 2006 | 05:54 PM
yee SERIOUS's Avatar
it all depends. you could run a sc61 if your tune is good. but for longetivity, stick to the common t3/to4e.
i would say determine a hp goal and start parting things together slowly. i highly recommend you start researching and see what other people do for ls turbo setups. ALSO search for a tuner near you. GL
Old Jun 26, 2006 | 07:46 PM
adseguy's Avatar
Default Re: (AdamO)
Yeah, you can always push up the PSI, but just have to re-inforce the internals eventually. I'm not saying you can't go over 9 psi, but if you're using a bone stock engine and racing it with that much boost, it's not going to last long.</TD></TR></TABLE>
[BS police] Please don't say that. PSI is not what breaks internals. Under normal combustion around 2500PSI of pressure is in the combustion chamber what is 9PSI or even 40PSI or air to that really going to hurt.... . Then what should we look at? Cylinder pressures! Cylinder pressures create HP . So.....the norm for HT is aroun 280-300whp for a bone stock LS. If you don't believe it. I have over 15k miles on a stock 328whp on 18PSI and I'm not nice to it . [/BS police]
For the OP, go ahead and list a power goal and how much money you have to spend. I feel nice and can probably give you a little list.
Old Jun 26, 2006 | 09:26 PM
sleeplsm's Avatar
* B A N N E D *
Default 18 PSI on stock internals Sounds Sicc
Tell me what to get I got about 1200 coming real soon
Old Jun 26, 2006 | 09:34 PM
sleeplsm's Avatar
* B A N N E D *
Default Re: 18 PSI on stock internals Sounds Sicc
What fuel pump, injectors cams? boost control turbo size/trim.
Old Jun 26, 2006 | 10:58 PM
mtber's Avatar
Default Re: 18 PSI on stock internals Sounds Sicc (sleeplsm)
For efi info, read over: http://phearable.net/tech/efibeginnerguide.html
For the rest of the info concerning whp limits of the motor, search.
Old Jun 27, 2006 | 12:16 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeplsm &raquo;</TD></TR><TR><TD CLASS="quote">Tell me what to get I got about 1200 coming real soon</TD></TR></TABLE>
$1200 on a turbo setup is not enough. If you go on Homemadeturbo.com. They will be much nicer in helping piece together a little turbo setup. IMO without at least $2000 I'd just save up more.
Old Jun 27, 2006 | 12:36 PM
sleeplsm's Avatar
* B A N N E D *
I have so many resources its not even funny 1200 hun will be enough for me and not no homemade **** either i just want to see what other poeple have and or compare
Old Jun 28, 2006 | 07:03 AM
adseguy's Avatar
https://honda-tech.com/zerothread?id=1323059 188 pages to sift through
Old Jun 28, 2006 | 09:58 AM
bboysake's Avatar
Well I have a LS-T too and people have been telling me that 12 psi will run on stock internals. But the question is how long will it last? I got a Custom turbo kit with a T04e turbo for $2000 It'll be hard to find a turbo kit for $1200 cause you need to get your oil pan tapped, better oil, Oil lines, etc. etc. etc. It just keeps on going man. I am barely finished with my project and it's been like 3 months for me.
Old Jun 28, 2006 | 10:48 AM
https://honda-tech.com/zerothread/1668964
Old Jun 28, 2006 | 10:56 AM
20geezer00's Avatar
$1200 isn't much... my .02 don't cheap out on things, you'll end up paying for it later...
sonne_side
Mar 31, 2009 08:23 PM
peacemaker
Oct 25, 2007 02:22 PM
JDMI3I2AD
Sep 8, 2007 03:01 PM
lubmyinteg
Feb 26, 2006 06:03 PM
TURBODC4TEG
Sep 22, 2004 12:45 AM
