Weight/mileage question
Old Jun 25, 2006 | 08:20 PM
ck123's Avatar
Default Weight/mileage question
how much does 1 gsr fat five weigh with tires?
how much does 1 13 inch steelie weight with tires?
if i upgrade my 13 inch steelies to 15 inch fat fives will i lose mileage??
if anyone has personal experience lemme know plzzzzzzzzz
greatly appreciated
Old Jun 25, 2006 | 08:26 PM
old man neri's Avatar
Default Re: Weight/mileage question (ck123)
Changing the size of your rims should have no effect on milage. Any milage change would be a result of changing the model of tire and/or using different pressures.
Weight is only a factor when accelerating. Add more weight will require a bit more energy to get up to the same angular velocity.
Also to note: If you save weight by getting a smaller rim you probably have to add weight by getting a bigger tire.
Old Jun 25, 2006 | 08:32 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Weight/mileage question (old man neri)
The difference in weight between different wheels and tires isn't enough to affect your gas mileage significantly.
Old Jun 25, 2006 | 08:55 PM
ck123's Avatar
alright cool that sums up my questions
alwaysoverkill
Dec 13, 2006 03:42 PM
superpilun
Dec 17, 2005 11:52 AM
Monkey Fing a Coconut
May 1, 2004 01:50 AM
micrew
Jan 7, 2002 07:27 AM
