hooking up the door trigger for clifford alarm?
I have a 97 ex civic and I recently installed a clifford bullet 4 alarm system (myself). The problem i am having is that i read the intructions wrong and i hooked up the the door trigger wire to my driver's door only, so when i open the passenger doors the alarm doesn't ring.
I have read in the chiltons the color of the one wire that connects all four doors (i have a sedan) and i'm guessing this is the correct wire that i hook up the door trigger wire too but to find the wire is like finding a needle in a haystack. If anyone has done this before can u give me a hand to where that wire is, or if it is connected to the fuse box somewhere!!!!!
thanks in advance
thanks in advance
easy way to fix your problem.
1. disconnect the door trigger wire(from the clifford alarm) from the drivers pin completely
2. tag the clifford wire to the pass. door pin only (That wire will catch all the doors)
good luck
[Modified by t, 7:45 PM 4/18/2002]
good luck
