00 Si NEED HELP
Old Jun 25, 2006 | 02:32 PM
MugenManR's Avatar
Default 00 Si NEED HELP
ok so im about to buy and si and im kinda iffy about it, its got the b16 in it, its black, sun roof power eveything gauges and all , but its missing the lip, and i wanted to know what it came with stock so if you could help it would be great.
i want to know what the grill has on it and stuff that would point out that its an si
Old Jun 25, 2006 | 02:42 PM
BlueIntegraBoy's Avatar
Default Re: 00 Si NEED HELP (MugenManR)
Check the VIN: 1HGEM1...
The stock lip can be removed from the bumper.
Old Jun 25, 2006 | 02:46 PM
krisjk2's Avatar
Default Re: 00 Si NEED HELP (BlueIntegraBoy)
the engine should be b16a2, si gauge cluster, yada yada, rear disks, mesh grill, si badge on back, DOHC VTEC badges on the sides.
that si front lip will be hard to find. you can order a color matched one from honda for around $270
Old Jun 25, 2006 | 02:59 PM
Targa250R's Avatar
be professional
If the VIN starts with "1HGEM1 . . . " then it is an Si chassis. If it starts with anything else (like "1HGEJ8 . . . "), it is not an Si.
Old Jun 25, 2006 | 03:02 PM
blkSi's Avatar
yeh, what these guys said... and im pretty sure there's more than one place to check the vin
Old Jun 25, 2006 | 03:41 PM
Sean @ ESG's Avatar
vin would be easiest...
Old Jun 25, 2006 | 04:02 PM
Syndacate's Avatar
Default Re: (banzai msg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg &raquo;</TD></TR><TR><TD CLASS="quote">vin would be easiest...</TD></TR></TABLE>
and the most efficient, those badges are transferable, I've seen people do tons of sticker swaps and **** on different cars to make it appear as different trims (like GT badgets, etc.) -- The engine VIN wouldn't do u ne good because it could just be a B16 from anotehr 99-00 si, the one under the window on the dash is ur best bet, it's an EM1 chassis which as people already stated, starts with 1HGEM1..
Old Jun 25, 2006 | 07:35 PM
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
and the most efficient, those badges are transferable, I've seen people do tons of sticker swaps and **** on different cars to make it appear as different trims (like GT badgets, etc.) -- The engine VIN wouldn't do u ne good because it could just be a B16 from anotehr 99-00 si, the one under the window on the dash is ur best bet, it's an EM1 chassis which as people already stated, starts with 1HGEM1..</TD></TR></TABLE>
The dash VIN can be removed. Check VINs at different locations (firewall, every panel should have a VIN sticker if it hasn't be replaced).
Old Jun 25, 2006 | 07:42 PM
cambopheonix56's Avatar
Default Re: (BlueIntegraBoy)
The dash is also a darker grey, almost a black. But that can be changed also.
Old Jun 25, 2006 | 07:44 PM
Default Re: (cambopheonix56)
And the grill will look like:
XXXXXXXXXXX
XXXXXHXXXXX
XXXXXXXXXXX
If it was an ex:
-------H---------
But, once again. Easy to change bumpers.
Old Jun 25, 2006 | 07:59 PM
MugenManR's Avatar
i want to thank you all for your help. i will post pics once i get it. and if anyone has pics of clean black si, then show em i need ideas
Old Jun 25, 2006 | 09:29 PM
E46Kid's Avatar
Default Re: (MugenManR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR &raquo;</TD></TR><TR><TD CLASS="quote">i want to thank you all for your help. i will post pics once i get it. and if anyone has pics of clean black si, then show em i need ideas </TD></TR></TABLE>
look in the em1 crew thread in the appreance/cosmetic forum
Old Jun 25, 2006 | 11:10 PM
Frozen E's Avatar
H-T White Ops
Headrests are also hollow, All other trims have solid headrests.
Old Jun 26, 2006 | 01:07 AM
jdmctrek9's Avatar
good advice honda techsters
EG6-baybee
Sep 6, 2008 07:22 PM
twenty
Nov 30, 2005 10:15 AM
sumo
Feb 9, 2005 10:47 PM
