Which wires do I cut and solder to my speakers in an integra?
Old Jun 25, 2006 | 02:17 PM
Jay J's Avatar
Prince of Zamunda
Default Which wires do I cut and solder to my speakers in an integra?
What do I cut and where do I solder on to?
Thanks?
Old Jun 25, 2006 | 03:15 PM
Jay J's Avatar
Prince of Zamunda
Default Re: Which wires do I cut and solder to my speakers in an integra? (Jay J)
Help?
Old Jun 25, 2006 | 03:37 PM
Jay J's Avatar
Prince of Zamunda
Nobody wants to help
Old Jun 25, 2006 | 04:00 PM
8520's Avatar
No, this is just a slow moving forum and you're impatient.
Old Jun 26, 2006 | 04:59 PM
thatasiankidtony's Avatar
Try http://www.installdr.com They usually have solutions.
Old Jun 26, 2006 | 05:02 PM
B18C_EJ8's Avatar
You shouldn't be cutting anything to begin with. Get the appropriate speaker harnesses, plug them in and you're done. No soldering involved.
And as previously stated, it's not necessary to bump 3 times in an hour on this forum.
Old Jun 26, 2006 | 05:33 PM
audioroach's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't be cutting anything to begin with. Get the appropriate speaker harnesses, plug them in and you're done. No soldering involved.... </TD></TR></TABLE>
Yes please stop being a cheap bastid (J/K) and buy the plugs-they are only 5-8 bucks and make your life so much easier-ie no screwups.
go play nice
Old Jun 26, 2006 | 05:57 PM
02 accord's Avatar
Did you really have to ask? There are 2 wires of each color at the plug, meaning that the same color wires are connected together. So cut off the plug, solder the same colored wires together, and then solder them onto the speaker terminals. Use the installdr website to figure out which color is positive. Then, connect that to the wider tab on the speaker. And it should be obvious already, connect the negative wire to the smaller tab.
Old Jun 26, 2006 | 06:04 PM
audioroach's Avatar
Default Re: Which wires do I cut and solder to my speakers in an integra? (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Did you really have to ask? There are 2 wires of each color at the plug, meaning that the same color wires are connected together. So cut off the plug, solder the same colored wires together, and then solder them onto the speaker terminals. Use the installdr website to figure out which color is positive. Then, connect that to the wider tab on the speaker. And it should be obvious already, connect the negative wire to the smaller tab.</TD></TR></TABLE>
See its just that 'obviuos logic' that proves that not everyone should install their own gear (trust me... I made more in service diagonstics and repair charges today then I have in my whole career ) Some people should just put the tools down and just walk away and seek professional help.
Old Jun 27, 2006 | 11:32 AM
Skip01's Avatar
As said buy the cheap harness and your good to go.
Old Jun 29, 2006 | 01:36 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Which wires do I cut and solder to my speakers in an integra? (audioroach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach &raquo;</TD></TR><TR><TD CLASS="quote">
See its just that 'obviuos logic' that proves that not everyone should install their own gear (trust me... I made more in service diagonstics and repair charges today then I have in my whole career ) Some people should just put the tools down and just walk away and seek professional help.</TD></TR></TABLE>I'll have to agree with you on that one.
Old Jun 30, 2006 | 04:57 AM
Jay J's Avatar
Prince of Zamunda
Default Re: (Skip01)
All I was asking was which color was positive basically and by logic I found that the larger tab on the new speakers are the + terminals
Old Jun 30, 2006 | 05:02 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> basically and by logic I found that the larger tab on the new speakers are the + terminals
Ohhh... Because the + and - stamped into the white part of the terminal plate didn't clue you in? And you could have opened the manual and seen that too...
Old Jun 30, 2006 | 05:18 AM
Jay J's Avatar
Prince of Zamunda
Ohhh... Because the + and - stamped into the white part of the terminal plate didn't clue you in? And you could have opened the manual and seen that too... </TD></TR></TABLE>
Manual?
Where? lol (there wasn't one)
Nothing was stamped onto the terminal plate either
Old Jun 30, 2006 | 05:38 AM
B18C_EJ8's Avatar
Good call... Because I forgot they don't put manuals/spec sheets online anymore...
sohcvtec91hatch
11
Jul 3, 2007 05:17 PM
Ep1dem1c
Jul 3, 2007 10:51 AM
pr1mo_13
Jul 19, 2005 06:38 PM
Blazin Civic
Jun 3, 2004 11:31 PM
Dohc.MAD
12
Apr 19, 2004 04:28 PM
