how to: rear interior plastic removal
Old Apr 17, 2002 | 05:27 PM
magic hat #9's Avatar
Default how to: rear interior plastic removal
this is an easy process with the only difficulty coming from being hunched over in the little hatch in work clothes and an ambient air temp over 80deg. this whole process could be done in under 30min or in 5 short intervals broken up by trips to the ac in the store. let's get started:
there are 4 x 10mm bolts holding in the plastic side panels. one is hidden under the driver's side shock tower panel, here are the other 3 in these deep wells.
once the bolts are out, there are 6 x plastic-screw clips also holding in the plastic, just search them out and remove 'em. now pry the plastic away from the wall of the car. i started in the front pulling the plastic off the door jamb, then worked my way up and across the rear side glass. a couple of hard yanks will pull the plastic out of it's clips that secure it to the wall.
big chunk of plastic removed.
here is what it looks like under there. i was happy to find all the wires/hoses are well hidden so they won't get damaged when i throw tires and tools in there.
seat belt removal, 14mm bolt.
the seat belt retractor thingy, 3 x 14mm bolts and 1 x 10mm bolt. the metal ring the rear seats clip onto, 2 x 10mm bolts.
one word of caution, i can tell that it will not be an easy job to put the plastic pieces back in; certainly it can be done with a little pushing and muttering of expletives.
i will have a description of the noise levels a little later tonight after i pick up my sushi dinner!
Old Apr 17, 2002 | 05:35 PM
hungsteR's Avatar
Default Re: how to: rear interior plastic removal (monkey_truckR)
Badass bro'. Keep up the good work. A little suggestion though. The next How To should be:
How to drop in a JDM Final Drive
LOL
[Modified by hungsteR, 8:35 PM 4/17/2002]
Old Apr 17, 2002 | 05:41 PM
B2FiNiTY's Avatar
Sweet man, thanks to you I have some how to's on my site. Keep up the good work.
Old Apr 17, 2002 | 05:55 PM
D's Avatar
D
jesus... enough with the how to for jerry's kids...
HELMS!
oh, and btw, you're taking them out the wrong way.
[Modified by D, 9:56 PM 4/17/2002]
Old Apr 17, 2002 | 06:00 PM
Tommy_Gunns's Avatar
Default Re: how to: rear interior plastic removal (D)
You should start from the rear of the car when removing the panels (much easier and less likely to break something).
Old Apr 17, 2002 | 06:04 PM
Faust's Avatar
What is the "right" way?
Old Apr 17, 2002 | 06:05 PM
AssPenny's Avatar
Default Re: how to: rear interior plastic removal (Tommy_Gunns)
Old Apr 17, 2002 | 06:06 PM
01TypeR680's Avatar
New User
Default Re: how to: rear interior plastic removal (Faust)
you forgot the step at the end where you're supposed to down a once finished -rob
Old Apr 17, 2002 | 06:09 PM
AssPenny's Avatar
Default Re: how to: rear interior plastic removal (01TypeR680)
Hell yeah.... i don't see a beer in any of thouse pictures... not even a middle finger... what the hell is wrong with you
Just to help u out...
Old Apr 17, 2002 | 06:14 PM
AllMotorITR's Avatar
New User
Default Re: how to: rear interior plastic removal (AssPenny)
Who's in the picture, from left to right?
Old Apr 17, 2002 | 06:17 PM
AssPenny's Avatar
Dave (FL/NC rocks or some **** like that...), Yack (B18CxR), Yours truely, Tom Green... err I mean Matt (D). Jason is behind the camera.
We were doing an ATS FD install
[Modified by AssPenny, 10:17 PM 4/17/2002]
Old Apr 17, 2002 | 06:29 PM
Rob :190:'s Avatar
hell yeah, thems some ITR-NC/FL
Old Apr 17, 2002 | 06:31 PM
AssPenny's Avatar
Default Re: how to: rear interior plastic removal (Brian Spilner 1035)
Got 2 others you might recognize
Old Apr 17, 2002 | 07:28 PM
Default Re: how to: rear interior plastic removal (hungsteR)
LOL
hehe, the car will remain stock after the next few goodies: autopower rollbar (on order), sparco evo, harness, and a rear strutbar. this will be the last how-to for awhile as there isn't too many more cheap things to do. aleph did an excellent job on the rollbar and harness so there is no need to duplicate. i should hope no one needs a tutorial on the strutbar install.
Old Apr 17, 2002 | 07:29 PM
B2FiNiTY's Avatar
No need but do one anyways!
Old Apr 17, 2002 | 07:31 PM
HELMS!
don't read 'em if you don't like it. i don't do spend my time doing this for you. i post this stuff because people ask how to do this simple stuff 2-3 times a day.
Old Apr 17, 2002 | 07:35 PM
just completed that step!
it may be just as easy to remove the panels from the back to forward, i don't know. i certainly didn't have a hard time or feel i was in danger of breaking anything going from front to back. just be mindful of the rear seatbelt and it's easy enough.
Old Apr 17, 2002 | 08:16 PM
Faust's Avatar
Don't sweat it. You did a great job. I have the seats out...and I did it without a manual Mr. HELMS. I was thinking about taking the plastic out too, but I am not sure I like the look of the bare metal inside.
D16Z6racing
Jan 18, 2011 08:05 AM
'95 BA8
Dec 25, 2007 06:39 AM
lke2drvgsr
Jan 8, 2004 02:10 PM
Integra_Boi
Feb 21, 2003 05:38 AM
ITRacer121
Jul 1, 2002 02:22 PM
