dizzy cap for b16a?
Old Jun 24, 2006 | 10:49 PM
EF86's Avatar
Default dizzy cap for b16a?
the dizzy cap on my b16a on my EF is going bad.it is leaking oil.and im not sure if its the rotor or the distributor cap.i went to kragen and picked a 92 gsr cap and it didnt fit.dont know what else to try.any help will help.
Old Jun 24, 2006 | 10:56 PM
bag's Avatar
bag
Default Re: dizzy cap for b16a? (EF86)
you gotta use obd0 cap .
90-91 integra ls,rs,gs or 88-91 civic/crx si,dx,ex,lx,std,hf doesnt matter same **** all works
Old Jun 25, 2006 | 07:14 AM
efcivic757's Avatar
Best cap and rotor to use is oem type-r. Actually built better for use at high revs.
Old Jun 25, 2006 | 05:39 PM
EF86's Avatar
koo.ill try the type R and c how that goes.thanks for the input
Old Jun 25, 2006 | 07:05 PM
Crx Jimmy's Avatar
Default Re: (efcivic757)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efcivic757 &raquo;</TD></TR><TR><TD CLASS="quote">Best cap and rotor to use is oem type-r. Actually built better for use at high revs.</TD></TR></TABLE>
thats not going to work unless he is obd1 , of its obdo try a 91 integra cap also replace the gasket around the cap, if oil is leaking externally you need a new dizzy o ring, if it leaks into the dizzy the inside shaft is worn and you need a new dizzy
Old Jun 25, 2006 | 10:05 PM
bag's Avatar
bag
Default Re: (EF86)
not gonna work for him,,now the poor guy is gonna have two caps that dont fit..like i said before ,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">you gotta use obd0 cap .
90-91 integra ls,rs,gs or 88-91 civic/crx si,dx,ex,lx,std,hf doesnt matter same **** all works</TD></TR></TABLE>
Old Jun 25, 2006 | 10:34 PM
SiR Inspired ED7's Avatar
Default Re: (bag)
Old Jun 25, 2006 | 10:44 PM
b18_crx's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
if it leaks into the dizzy the inside shaft is worn and you need a new dizzy </TD></TR></TABLE>
thats what i was thinking, why would it need a new cap? there's not supposed to be oil inside ditributor!
Old Jun 26, 2006 | 09:27 PM
EF86's Avatar
i have an obd1.harness came straight from DA .but ill try that type R tomm.let u guys know how she runs.yea i found oil on the inside of the cap
Old Jun 26, 2006 | 09:28 PM
Default Re: (EF86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF86 &raquo;</TD></TR><TR><TD CLASS="quote">i have an obd1.harness came straight from DA .but ill try that type R tomm.let u guys know how she runs.yea i found oil on the inside of the cap</TD></TR></TABLE>
¿Que?
Old Jun 26, 2006 | 09:32 PM
RCautoworks's Avatar
AW what, where did you get this info from ?
hondapimp125
Dec 15, 2008 08:27 AM
dingusjt
15
Oct 13, 2004 02:17 PM
8ball629
Mar 31, 2004 08:43 PM
