Semi-built B16...problems oh lord.
Old Jun 24, 2006 | 07:28 PM
Tuesday Club's Avatar
Default Semi-built B16...problems oh lord.
I recently (today) put together a B16 w/ the following:
RM valvetrain
Crower 402 cams
aebs IM
custom filter
Stock B16 block w/ >70,000 miles
new Water pump
new seals
new gaskets
ETC.
My problems are the following:
Idle sucks complete A$$....rough as Sh*T
Through the breather port (on valvecover) white smoke pours out when revved
cyl. 3 has some rich fuel issues.....
I am at a loss......I've spent HOURS trying to figure this out till my hands have bled (literally)
Biggest problem...The smoke from ther valve cover....Oil pressure is good, temp is good, valve adj. was cool, timing=dead on.
Please help, I've spent lotsof money, and feel like it was a waste
TIA
Modified by Tuesday Club at 12:33 AM 6/26/2006
Old Jun 24, 2006 | 08:05 PM
Default Re: Semi-built B16...problems oh lord. (Tuesday Club)
Forgot to mention......93 cx obd1 motor blah blah blah
I am currently drinking my sorrows away i apologizze
ALso, I had an epiphany,
the idle prob. could be caused by mixed up plugs..Ie evap. purge/iac/breather/ etc.
~if someone has the wire colors/etc, let me know.....i am depressed
Old Jun 25, 2006 | 08:32 AM
bump.....
Also, would a crappy fitting hondata IM gasket cause problems?
need reasons why white steam/smoke is coming from VC
Old Jun 25, 2006 | 10:50 AM
anyone????????? I need this pile back on the road soon..............
Old Jun 25, 2006 | 04:39 PM
PyroProblem's Avatar
Man that white smoke pouring out the valvecover sounds like bad rings...
Try this...with the car idling, pull off one plug wire at a time and see what cylinder doesnt make a difference...Then you might want to run a compression and leakdown test...
Check these first before gong farther.
Old Jun 25, 2006 | 06:43 PM
Default Re: (PyroProblem)
I have already done the wire trick: no cylinder was bad.
I have had bad rings before ( diff. motor) and never had white smoke out of the valvecover.
I fixed the idle prob. today, but I am having a difficult time understanding the white smoke issue.
BOTTM LINE......What is (are) the cause(s) of white smoke (smells like gas a bit) coming from the VC breather tube? I will be getting another ecu soon: I am currently using an LS in safe-mode, and hope this will ease the rough idle more.
TIA
EDIT:::::: Exhaust is clean....NO smoke whatsoever::::::
Modified by Tuesday Club at 12:34 AM 6/26/2006
Old Jun 25, 2006 | 09:29 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
fried ringlands?
Old Jun 26, 2006 | 06:21 AM
Default Re: Semi-built B16...problems oh lord. (DBL)
possibly.......But why is the smoke ONLY coming from the VC?
I will hopefully be able to do a comp. check today
Old Jun 26, 2006 | 06:39 AM
longuyen88's Avatar
how did you fix the idle prob?
Old Jun 26, 2006 | 08:22 AM
lightcrx's Avatar
did you rebluild the bottom end? take the pistions to check them?
have you seen the motor run before(if it was not rebuilt)?
could be oblonged cylinders causing extreme blowby
-joseph
Old Jun 26, 2006 | 11:17 AM
Default Re: (lightcrx)
The bottom end was re-built one year previous by a friend....ran fine.
He gave it to me 3 months ago, assuming it was fine, I put my brand new head on it.
The idle prob. was a vaccuum issue/pcv/iacv screw up on my part. It has been dealt with.
NOW, today, I removed the dipstick and white smoke was coming out of there as well. Is this a sign that the pistons need to be checked and new rings put on? Or is there some other reason this is happening?
Old Jun 26, 2006 | 12:00 PM
Throwdown's Avatar
Default Re: (Tuesday Club)
well this happend not to long ago to a friend, white smoke out the VC at the line we looked it over and over ...took it apart and the ringlands were so fucked.... good luck but thats what i think it is.
Old Jun 26, 2006 | 12:33 PM
hybrid1990crx's Avatar
Default Re: (DBL)
yeah sounds like blow by to me. out of the valve cover is a tell tale sign of this. sucks dude
Old Jun 26, 2006 | 01:18 PM
Default Re: (hybrid1990crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">yeah sounds like blow by to me. out of the valve cover is a tell tale sign of this. sucks dude </TD></TR></TABLE>
How do I fix this?
What causes this?
Old Jun 26, 2006 | 03:27 PM
lightcrx's Avatar
rings or broken pistions( ringlands)
-joseph
Old Jun 26, 2006 | 05:44 PM
cool....now assuming this is the only problem, do I just need to replace the rings? Or, should I be concerned about the block?
I am new to bottom end whoas.....
Old Jun 26, 2006 | 08:06 PM
Throwdown's Avatar
no if it is the ringlands are fried i would get some .20 over pistons or whatever new ring's bore it a lil and be done.
Modified by DBL at 12:21 AM 6/27/2006
Old Jul 1, 2006 | 06:08 PM
crawlin's Avatar
Default Re: (DBL)
you should be able to have cylinders bored a tad and throw some .20 over's in there and be ok just make sure everything is put together right an spend the extra money and get all the internals put in by a shop
jhuerto23
Feb 14, 2013 08:06 PM
dannyly17
Apr 27, 2010 08:47 AM
keren
Sep 5, 2009 08:56 AM
wendunf
Jan 9, 2007 09:55 AM
slowsi00
Dec 5, 2002 06:25 PM
