differance in si and dx head?
Old Jun 24, 2006 | 06:50 PM
stemiched's Avatar
Default differance in si and dx head?
alright so i have a parts car that i know is all stock si. and i have a daily driver that i know is the body of a dx and the block seas d16a6... so i know the block is from an si. how can i tell if the head is from an si or not? or would the only head that would fit on the d16a6 block be an si head as well? im sorry for the most likely stupid question but i am young and we all needed to get told by someone before we knew the answer... i know there all posts about the differance in engines, but never about the head in particular. i just want to know if i should swap the head from my parts car into my daily driver. how can i tell what head it is?
Old Jun 25, 2006 | 03:57 AM
mullenite's Avatar
Default Re: differance in si and dx head? (stemiched)
There should be letters/numbers cast in to the head. They normally correspond with the ECU code so I would say look for "PM6" cast around the exhaust ports to see if it's an Si head. Someone else can confirm the letters but from my experience with other hondas that will tell you.
Old Jun 25, 2006 | 04:00 AM
91SiZ6's Avatar
The only difference between the D15B2 and D16A6 head is the cam. Look at the head, just below where the valve cover mates to the head and roughly between cylinders three and four (closest to the distributor). If you see a PM6 it's the A6 head and if you see a PM5 it's the D15B2 head. This will be small but you also have a small search area so it shouldn't be too difficult.
Old Jun 25, 2006 | 06:15 AM
stemiched's Avatar
Default Re: (91SiZ6)
alright so is there much of a performance differance? is it worth doing a swap or not really?
Old Jun 25, 2006 | 06:23 AM
stemiched's Avatar
Default Re: (stemiched)
um okay... it seas pm3-2 what head is that from?
Old Jun 25, 2006 | 06:25 AM
mullenite's Avatar
d15b7 i think.
Old Jun 25, 2006 | 06:30 AM
stemiched's Avatar
Default Re: (mullenite)
okay so is it worth swapping the head from my si parts car into my daily driver that has a pm3-2 head? also since i dont feel like opening a new thread and people reading this one probably know the answer. and pm5 ecu is from a dx correct?
Old Jun 25, 2006 | 06:48 AM
mullenite's Avatar
it shouldn't make a differance really. maybe a couple hp.
Old Jun 25, 2006 | 06:49 AM
stemiched's Avatar
alright well considering my lack of experiance and the small hp gain if even ill decide not to to do, the pm3-2 head is from a 92-95 civic dx correct?
Old Jun 25, 2006 | 06:54 AM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched &raquo;</TD></TR><TR><TD CLASS="quote"> and pm5 ecu is from a dx correct?</TD></TR></TABLE> yes your correct
Old Jun 25, 2006 | 08:04 AM
mullenite's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched &raquo;</TD></TR><TR><TD CLASS="quote">the pm3-2 head is from a 92-95 civic dx correct?</TD></TR></TABLE>
i believe so, they may have used the same casting for other motors however. how does the dizzy fit to the head? Is it cut up? if the car was converted to mpfi (4 injectors) you will need to use a PM6 (Civic/CRX Si) ecu and dizzy.
Old Jun 25, 2006 | 08:07 AM
stemiched's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullenite &raquo;</TD></TR><TR><TD CLASS="quote">
i believe so, they may have used the same casting for other motors however. how does the dizzy fit to the head? Is it cut up? if the car was converted to mpfi (4 injectors) you will need to use a PM6 (Civic/CRX Si) ecu and dizzy.</TD></TR></TABLE>
i havent took any notice to it beeing cut up, it has not been converted to mpfi, but i am going to do the mpfi swap soon and know that i will need the si dizzy and i have a pg7 ecu
Old Jun 25, 2006 | 08:11 AM
mullenite's Avatar
doesn't have to be a PG7. any mpfi ecu will work PM6 from an Si and PM8 from an HF will work also.
Old Jun 25, 2006 | 08:30 AM
stemiched's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullenite &raquo;</TD></TR><TR><TD CLASS="quote">doesn't have to be a PG7. any mpfi ecu will work PM6 from an Si and PM8 from an HF will work also.</TD></TR></TABLE>
i know it doesnt have to be a pg7. but i was told that will be the best set up without being chipped. and i already have the pg7 so no reason to get a different one.
4th gen civic racer
Jan 26, 2005 06:39 AM
DOHClessEF-9
Jan 2, 2005 01:41 AM
civicracer1993
Mar 9, 2004 08:26 AM
Broken Gearbox
Apr 5, 2003 10:48 PM
h8tred
18
Mar 31, 2003 02:27 PM
