civic/integra swaybar
1-2 mm is a sizable increase in bar stiffness depending on what size you are starting at.
going from a 15mm to a 17mm is an ~65% stiffer bar, and going from a 28mm to a 30mm bar is an ~32% increase in stiffness. taken from here
whether that will transfer perceptibly on the road or track is beyond my experience. ive made far more drastic jumps than 2mm. i went from on rear bar to a 13mm ls bar to a 21mm blox. the difference between each of those was huge, but i cant say whether or not i would notice 2mm.
but then again my car was pretty much excusively street
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saver »</TD></TR><TR><TD CLASS="quote">how relieble are the oem sway bars. </TD></TR></TABLE>
OEM usually means pretty damn reliable....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4civichatch »</TD></TR><TR><TD CLASS="quote">
OEM usually means pretty damn reliable....</TD></TR></TABLE>
would you be needing a stronger sub brace for it?
OEM means like factory made. If you want "oem" you want FACTORY parts. There is a difference. There can be like an OEM spec water pump made for your civic but, it may not be factory.
Yes any marginal size difference is significant.
TegoDC5
Suspension & Brakes
14
Sep 13, 2005 08:45 AM
jdm_23_eg6
Suspension & Brakes
Apr 3, 2005 03:32 PM
Skeletor
10
May 20, 2003 06:22 PM
