where to get a new crx steering rack??
Old Jun 24, 2006 | 04:58 PM
looxs's Avatar
Default where to get a new crx steering rack??
I dont wanna to rip mine apart and replace parts so i'm probably just buy a new one...anyone know where i can get one for a good price??
Old Jun 24, 2006 | 05:32 PM
Walshie's Avatar
Default Re: where to get a new crx steering rack?? (looxs)
I dunno wear your located but we have pretty good junk yard prices here... try car-parts.com
Old Jun 24, 2006 | 09:25 PM
gospeedgo1's Avatar
Default Re: where to get a new crx steering rack?? (Walshie)
what do you need to replace? i just took my steering rack out and replaced the rack end bushing. about $10 in parts. its pretty easy. the hardest part was religning the shaft from the steering shaft to the steering rack. i think the rack isnt cheap at all. i thought it was in the 100s or 200s in price but i dont remember. if you rent the 5 piece front end kit from kragens, its a snap to take the upper ball joints off. couple of seconds with each side. i spent about 3 hours and i was fooling around and taking my time. my car feels completely different, a lot more solid and alot more feedback when driving it. your gonna have to take it all out and replace it with the new one anyways. why not keep it?
Old Jun 26, 2006 | 09:33 PM
looxs's Avatar
Default Re: where to get a new crx steering rack?? (gospeedgo1)
yea i just heard it sucked trying to get the old rack end bushing out. I have an extra rack thats just laying around here that i already pulled with the crossmember and i wanted to check if it was still good. Are there any tests i can perform on the rack when its off the car? Where did u get the rack end bushing and is it necessary to replace inner/outer tie rods?
Old Jun 26, 2006 | 09:42 PM
G0crxG0's Avatar
I have a steering rack in perfect working order, pm WITH OFFER if your interested
Old Jun 26, 2006 | 10:25 PM
SiRay13's Avatar
Default Re: (G0crxG0)
don't buy a new one, just rebuild yours, if you take out out, you can have it rebuilt in about 10 mins if you have the parts ahead of time, here's what you need- rack end bushing, new bearing, probably a new c clip and a dust seal, you can purchase all this from honda for about 15 bucks, and get the bearing from some place else, becaue i think with honda you have to buy the pinion with the bearing. Don't spend money on a rebuild or a new one.
Old Jun 27, 2006 | 01:28 PM
efyou's Avatar
Default Re: (SiRay13)
where would you get the bearing by it self then? i dont have a clue when it comes to suspension but you think i can do it in a day?
Old Jun 27, 2006 | 01:45 PM
Tyson's Avatar
Default Re: (efyou)
https://honda-tech.com/zerothread?id=1117870
its easy when the rack is out.
Old Jun 27, 2006 | 01:49 PM
gospeedgo1's Avatar
Default Re: (Tyson)
it took me 2-1/2 hours to do mine completely, and i was goofing around with the hammer trying to get the ball joint off and a trip to kragens to get the ball joint puller tool. when you have the rack off and right tie rod off, push the rack so that the right side is even with the rest of the rack, then use little slotted screwdrivers to push the little buttons on the plastic bushing. then use the little screwdrivers to push the bushing out. im not sure about the pinon and bearing, probably like 15 more minutes if that.
dubyas1989
Mar 17, 2013 07:54 AM
RanCRX
10
Oct 9, 2007 05:44 PM
superex87
Jul 2, 2007 10:35 AM
LSV_REX
Apr 3, 2006 09:16 AM
JokerTypeR
Nov 21, 2005 02:52 PM
