Weird high pitched sound when starting gsr motor
Old Jun 24, 2006 | 02:43 PM
phanatic's Avatar
Default Weird high pitched sound when starting gsr motor
When i start my car it makes a high pitched sound like someone scratching their fingers on a chalkboard. It doesnt do it everytime i start it though. Car has plenty oil and the belts are tight. My last motor did it too whenever i started the car.
Old Jun 25, 2006 | 06:09 PM
subgeniusdude's Avatar
Default Re: Weird high pitched sound when starting gsr motor (phanatic)
Check you distributor...sounds like the bearing is going out.
Old Jun 25, 2006 | 09:10 PM
CarAudioPro's Avatar
are you sure its not just the belts?
Old Jun 25, 2006 | 10:14 PM
BLKGSR24's Avatar
my abs unit use to do that. It was only every once in awhile, but then it just went away.
Old Jun 25, 2006 | 10:28 PM
IntegraLova's Avatar
Default Re: Weird high pitched sound when starting gsr motor (BLKGSR24)
It could be the power steering belt. Mine does that sometimes when i start the car and move the steering wheel. I just tighten the belt and it goes away.Hope thats the case with u.
Old Jun 26, 2006 | 09:14 AM
phanatic's Avatar
Default Re: Weird high pitched sound when starting gsr motor (IntegraLova)
I dont have power steering in the car. How do i check the distributor? It did it on my previous motor before i swapped it out. I'm starting to think the actual car is cursed. Sometimes the car wont start. It's sound really strong and when i turn the key the engine wont turn over and the brake light comes on, even though the E-brake is down. I have plenty of brake fluid in the car and i dont the car wont start cuz my brake pads are brand new.
Old Jun 26, 2006 | 09:23 AM
-Championship-'s Avatar
76.169.175.137
might be the timing belt or any other belt, check em right...belts have that sound right when starting the car, put some belt grease from auto zone
Old Jun 26, 2006 | 10:17 AM
crx_88_si's Avatar
maybe its not the car, but you. are you holding the key to the start position a little long maybe??
Old Jun 26, 2006 | 02:41 PM
phanatic's Avatar
Default Re: (crx_88_si)
I let the key go as soon as the engine turns over. I'll check all the belts. It's ok to grease em up? They wont slip?
r22thomas
Apr 29, 2011 10:07 AM
avargas28
Jan 12, 2009 09:09 AM
em1gangsta
12
Jun 17, 2008 10:56 PM
blakh
Nov 25, 2007 03:43 PM
dip-set
Jan 22, 2003 10:51 AM
