What is this hole in the block for??
b18a block, no pics right now...but if you are looking at the back of the block, this hole is located about 1 inch to the right, and 1/2 inch above the left port that you remove for a catch can. The hole is threaded and large enough for your pinky to fit in... oil temp sensor?
if its right under where the head bolts up
& its a pre-threded hole that does not lead into the block then its 4 a knock sensor
if its to the left of the oil filter & it leads into the block its where u oil pressure sensor goes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">knock sensor...
he said b18a, no knock sensor.
Yes its for the breather box, like the dude above me said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx »</TD></TR><TR><TD CLASS="quote">
Yes its for the breather box, like the dude above me said.</TD></TR></TABLE>
the breather box hole is to the right of the oil filter, already plugged it... this one is to the left of the oil filter, threaded... and large enough to stick your pinky in. Oil pressure sensor?
you could just take the sensor off a d series block and put it in. or a b series.
or im sure you could go to a hardware store and find something that will thread into it to block it off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx »</TD></TR><TR><TD CLASS="quote">so are you talking aout the breather nipple or the oil pressure sender hole....
-joseph</TD></TR></TABLE>
I have the breather fittings from honda, we are talking about the hole between the left breather fitting, and the oil filter...
krysted9354
Dec 28, 2008 12:43 PM
SkertySkerty
Jul 4, 2007 04:21 PM
