Paper ID tag on Tranny ?
Old Jun 24, 2006 | 02:22 PM
Rex-Si's Avatar
Default Paper ID tag on Tranny ?
I know most tranny's dont have there small paper ID sticker for long before they fall off. But mine still has it there. My question is can you ID the type of tranny if you know the tag #'s. Thanks Bitches
Old Jun 24, 2006 | 02:35 PM
Rex-Si's Avatar
Default Re: Paper ID tag on Tranny ? (Rex-Si)
I know somebody out there can answer this question.
Old Jun 24, 2006 | 02:37 PM
pinecone's Avatar
If they have it, give them longer than 13 minutes to answer, it is saturday night you know.
Old Jun 24, 2006 | 02:42 PM
Rex-Si's Avatar
Default Re: Paper ID tag on Tranny ? (pinecone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">If they have it, give them longer than 13 minutes to answer, it is saturday night you know.</TD></TR></TABLE>
But i want them to drop everything and run to my aid ,
anyway , i hear ya , just chiming in looking for a answer.
I searched with no luck on this one , which sucks cause i usually have pretty good luck on the HT searches.
Later,
Old Jun 24, 2006 | 03:48 PM
Rex-Si's Avatar
( cough , cough )
Old Jun 24, 2006 | 04:16 PM
white90crxhf's Avatar
did you check the faq?
https://honda-tech.com/zerothread?id=1551508
https://honda-tech.com/zerothread?id=1376560
https://honda-tech.com/zerothread?id=924613
https://honda-tech.com/zerothread?id=1091029
nuc79
Offline
667 posts [100%]
N. of Jax FL
1-17-2003
« Re: (SETI20) « » 9:38 AM 12/23/2004 Reply Edit
open the tranny up (see steps 1-6 under How to remove the transmission housing in the first post here: https://honda-tech.com/zerothread?id=596873 )
now count the teeth on this diff ring gear. then count the teeth on the small pinion gear that meshes with it. divide big number by small number. If it's 4.25, you've got an Si (or built-to-si-specs) CRX tranny.
If it's 3.88 (DX), you got taken.
this is what i did to make sure my transmission i bought off of ebay was an SI transmission.
kidwit93delsol
Dec 5, 2007 12:28 PM
89hatcher
Aug 7, 2007 07:19 PM
bcrosby51
Jul 26, 2007 12:11 PM
ToNY2012
Jun 7, 2006 02:53 PM
spiceisler
Oct 21, 2002 05:32 AM
