leaking main relay
Old Jun 24, 2006 | 12:31 PM
mullenite's Avatar
Default leaking main relay
Car won't start so the first thing I checked is the main relay. After remving the cover and looking, all the joints look fine but it looks like there is something leaking out of some of them. Similar to the way puss comes out of the top of an insect bite or pimple. The color of it is sort of like blood. I tried to take a picture but macro mode can't focus enough to be able to see it. What is this stuff? It smells almost like a resin but isn't sticky and doesn't even feel wet. Could this be why the car won't start? It's definatly not getting any fuel.
Old Jun 24, 2006 | 12:33 PM
dr_latino999's Avatar
Default Re: leaking main relay (mullenite)
Can't capacitors "bleed" when the age then burst? This may be what you are seeing.
Old Jun 24, 2006 | 12:57 PM
eda6's Avatar
Default Re: leaking main relay (dr_latino999)
it's probably flux and that's normal. you should be looking for dry joints. Those are little cracks in the solder around the joints. They look like rings and are hard to spot.
Old Jun 24, 2006 | 01:06 PM
mullenite's Avatar
Default Re: leaking main relay (eda6)
didn't see any cracks but i don't think there would be that much flux. I wish you could see it.
Old Jun 24, 2006 | 01:16 PM
m0t's Avatar
m0t
junk
Old Jun 24, 2006 | 01:57 PM
mullenite's Avatar
Default Re: (m0t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m0t &raquo;</TD></TR><TR><TD CLASS="quote">junk</TD></TR></TABLE>
care to elaborate?
Old Jun 24, 2006 | 02:00 PM
SFlCrx's Avatar
use a dmm and a wiring diagarm check for continuatiy and voltage to the relay then to the pump
Old Jun 24, 2006 | 02:07 PM
Rex-Si's Avatar
Main relay's arent that expensive man , just pick one up and replace that one.
That way you know for sure it good. If your not getting fuel chances are it bad.
Old Jun 24, 2006 | 02:28 PM
mullenite's Avatar
Default Re: leaking main relay (Rex-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex-Si &raquo;</TD></TR><TR><TD CLASS="quote"> Main relay's arent that expensive man , just pick one up and replace that one.
That way you know for sure it good. If your not getting fuel chances are it bad. </TD></TR></TABLE>
i have one on order but it takes a few days to get here and i have school tomorrow morning. (yes i have school on sunday.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFlCrx &raquo;</TD></TR><TR><TD CLASS="quote">use a dmm and a wiring diagarm check for continuatiy and voltage to the relay then to the pump</TD></TR></TABLE>
Half my tools are at my dads house which is about 30 minutes away, working with basically hand tools and few specialty tools (actually, only two: brass mallot, compression gauge.) Otherwise I would do this.
Old Jun 24, 2006 | 02:33 PM
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullenite &raquo;</TD></TR><TR><TD CLASS="quote"> (yes i have school on sunday.) </TD></TR></TABLE>
One word for you , Suckstobeyou !
whiteformula98
Aug 3, 2008 08:53 PM
rider07
Jul 8, 2007 08:55 PM
ninjagaiden
13
Jul 6, 2007 03:44 PM
95excoupe
17
Jun 17, 2007 03:47 AM
siregcivic
May 17, 2006 10:23 PM
