??? on Viper 791VX into a 92 Civic DX...
I have all my sensors mounted and wired... I have my brain mounted and all harnesses plugged up to it, and I also have my battery back up moudule mounted...
This is my first time installing an alarm so I am a little worried to mess something up... I am following the instrutions and suspendedhatch's write up...
My question is can I extend the Fat Wires coming off the Relay satellite?? Do I need to put more fuses or a relay or something?
The White/blue wire @ h1/3- (-) Remote Start Activation input- Can I just ground that? I have no clutch switch (i did an auto to manual....
The Black/white neutral Safety Switch wire @ H3/5- I just put this to the toggle switch and ground the switch right???
The orange fatty wire which is (+) accessory output - It to a wire that powers climat control?? huh?? can i just connect it to accesory on the fuse box?
fat Purple (+) starter output - starter wire?
fat Green starter input- anti grind starter kill- its says wire it to the key side of the starter wire??? I dont get that part....
Thanks for your help...
Yes you can extend the wires off the satellite pack. Just use the same gauge. Additional fuses are not necessary.
You don't need white/blue IIRC.
Yes, black/white goes to switch then to ground.
Large gauge orange wire off relay pack goes to the Accessory wire in the ignition harness.
Purple goes to Starter wire in the ignition harness.
For starter kill, you cut the starter wire in the ingition harness. The large gauge purple wire goes to the side of the wire you cut that is toward the starter. The large-gauge green wire goes to the other side of the cut wire (that goes to they key).
No problem.
No problem.
colnago
Audio / Security / Video
17
Nov 29, 2006 11:00 AM
b16_madman
12
Jul 28, 2004 05:39 PM
... Too bad they dont have Rep points here i would 've gave you some...
