90-93 DA integra radiator fittment problem
Old Jun 24, 2006 | 10:58 AM
west nile's Avatar
Default 90-93 DA integra radiator fittment problem
So, I am having problems lining up the hole for the drivers side radiator hold down, the bracket that attaches to the top of the radiator and bolts to the t bar, I can get one bolt in but not the other. I know that the radiator is like .10" taller and wider but that should not make this much of a difference right? I mean I am having troubles closing the hood! Anyone shed some light on this? I searched and everyone said this was a direct swap.
Also, the radiator is from Autozone.
Old Jun 24, 2006 | 11:09 AM
Crx Jimmy's Avatar
Default Re: 90-93 DA integra radiator fittment problem (west nile)
is it a plastic top or metal top rad? i have a plastic top and it was a bit of a squeeze, loosen the bracket on the other side and see if you can get the bolts in then tighten them both down. also I bent the bottom brackets(on the rad support) down a bit so the rad fit better. make sure the bottom tabs are in the holes in the brackets, good luck
Old Jun 24, 2006 | 11:16 AM
west nile's Avatar
cool thanks, I was thinking I would have to modify something.
Snailor Built
Welding / Fabrication
Aug 13, 2015 07:43 AM
Not_So_JDM
Jul 2, 2005 12:01 AM
AVATAR
Jul 7, 2003 03:08 PM
mikecel79
Jul 24, 2001 10:10 PM
