Turbo Oil lines!
Old Jun 24, 2006 | 10:24 AM
jdm91CrxSi's Avatar
Default Turbo Oil lines!
First Im asking three questions..
1. What do you run the oil supply line for the turbo from
2. Can you tap (put a T or a Y) into the oil line beside the oil filter for the supply line
3. Does that line go to the head?
Old Jun 24, 2006 | 10:37 AM
jdm91CrxSi's Avatar
Default Re: Turbo Oil lines! (jdm91CrxSi)
bump .. cmon you tech mojos
Old Jun 24, 2006 | 10:41 AM
dr_latino999's Avatar
Turbo Oil Lines for Dummies
Old Jun 24, 2006 | 02:12 PM
highroller54's Avatar
Default Re: Turbo Oil lines! (dr_latino999)
http://www.stealthmodeperformance.com
http://www.homemadeturbo.com
Old Jun 24, 2006 | 02:18 PM
bag's Avatar
bag
Get this ,,it screws into where the stock oil pressure sender is then the oil pressure sender gets screwed onto it..also you might need an oil rrestircitor dpend on what turbo you hgave
Old Jun 24, 2006 | 02:23 PM
Default Re: Turbo Oil lines! (bag)
You don't want to tee off the stock oil pressure switch, it'll eventually break and all hell breaks loose then.
94preluder3084
Jun 8, 2007 09:46 AM
MotorMouth
Mar 20, 2006 07:12 PM
b18cya
Feb 19, 2003 10:50 PM
blufke
Nov 4, 2002 10:25 AM
