JDM 2000 Yellow Foglights. How is power supply connected?????
So i bought the jdm yellow fogs for an ek from JHP and i was just wondering for the power supply, i only have a red wire for power. then it goes to the fuse and relay then down to the fogs. Is there supposed to be a negative power supply with the red wire or is the negative the grounds?. Also, do i connect the power to the fuse box or the battery? Thanks to all.
Did you buy the replicas? But anyways, there's a power and ground for the engine bay harness. The interior harness gets power from the fusebox and there's a ground too.
i bought the replicas, im just confused where to connect the red wire going to the battery side, also, the red wire is connected to a relay and fuse before it connect to the battery. I think it just connects to the positive side of the fuse box???
