what tire size for a 15x7 rim???
Old Jun 24, 2006 | 07:25 AM
LiL JoN's Avatar
Default what tire size for a 15x7 rim???
what tire size for a 15x7 rim 195/50/15 or 205/50/15 pics would be great..........thanks
Old Jun 24, 2006 | 07:30 AM
CRX Toad's Avatar
Default Re: what tire size for a 15x7 rim??? (LiL JoN)
205/50/15
I'm not 100% sure why you want a pic but here you go
Old Jun 24, 2006 | 07:38 AM
C1CRX's Avatar
Traffic signal tech
i like the 195/50/15 for the EFs instead. if your car is dropped less chance of it rubbing.
Old Jun 24, 2006 | 10:19 AM
Dark Star's Avatar
Old Jun 24, 2006 | 10:28 AM
Smokinsax's Avatar
The Boot
ive seen 195/45/15's on a CRX before. It looks a little weird but I sure as hell liked it.
Old Jun 24, 2006 | 10:32 AM
FernEF's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">ive seen 195/45/15's on a CRX before. It looks a little weird but I sure as hell liked it.</TD></TR></TABLE>
hm.. 45's on 15's... weird is right
Old Jun 24, 2006 | 11:10 AM
Crx Jimmy's Avatar
try some 225/45/15's
Old Jun 24, 2006 | 01:41 PM
d357r0y's Avatar
195/205.. hard to say without comparing each individual tire.
I had a set 195/50 yoko. AVS ES 100s and they were narrow compared to a set of 195/50 fuzion ZRIs. The ZRIs actually looked more like a 205 though they were measured as a 195.
Anyway.. I like 195s
Old Jun 24, 2006 | 01:46 PM
Hamstr323's Avatar
Default Re: (lvcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">i like the 195/50/15 for the EFs instead. if your car is dropped less chance of it rubbing.</TD></TR></TABLE>
Old Jun 24, 2006 | 05:53 PM
CRX Toad's Avatar
Default Re: (lvcrx)
FYI Rubbing a 205/50/15 in and EF has MORE TO DO WITH OFFSET. I have 205/50/15 pictured above and they don't rub. So Get out of here with the rubbing BS with a dropped car.
On the rear it has to do with offset and what brakes you have on.
Old Jun 24, 2006 | 06:16 PM
c0nspire's Avatar
id probably get 205's next time around although
Old Jun 24, 2006 | 06:24 PM
1990crxsir's Avatar
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">FYI Rubbing a 205/50/15 in and EF has MORE TO DO WITH OFFSET. I have 205/50/15 pictured above and they don't rub. So Get out of here with the rubbing BS with a dropped car.
On the rear it has to do with offset and what brakes you have on.</TD></TR></TABLE>
I agree. I have 205/50/15 with some cheap rims (manufacturer unknown). I have never had a tire rub problem and I am dropped pretty low. What I did notice is if the offset made the tire come out any further it would rub.
Old Jun 24, 2006 | 07:13 PM
Targa250R's Avatar
be professional
Default Re: what tire size for a 15x7 rim??? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">try some 225/45/15's </TD></TR></TABLE>
I run 225/45-15 Hankook RS2-Z212s on my 15x7" +40mm wheels
I previously ran 205/50-15 Azenis RT-215s on the same wheels.
Old Jun 24, 2006 | 07:36 PM
Hella_Fresh's Avatar
what did jon get now?
Old Jun 24, 2006 | 11:02 PM
Import Al's Avatar
Default Re: what tire size for a 15x7 rim??? (sXekid)
I have a ?? about offset since I'm going with this size wheel
(15x7's with 195/50 Potenza G 009's on a '91 Civic STD)
I've heard you are safe between +37 to +45 offset on EF's, but what offset would you recommend for a 1.25" drop (custom GC/Koni yellows) & 90-91 EX brakes without rolling the fenders?
Thanks.
..Stock rocks
Modified by Import Al at 8:13 AM 6/25/2006
Old Jun 25, 2006 | 06:30 PM
LiL JoN's Avatar
Default Re: what tire size for a 15x7 rim??? (Import Al)
thanks!!
CompanyFlow
Dec 23, 2004 12:20 PM
Sound Streamin'
23
Jul 15, 2004 06:47 AM
domanicivic
Jul 31, 2003 07:56 AM
1stealthls
Feb 7, 2003 11:22 AM
jond
Jan 27, 2002 09:02 PM
